Civil Engineering Association eBooks Journals, Papers and Presentations Analysis and design of the prototype of a steel 1-MW wind turbine tower
Likes: 9,404 in 1,160 posts
Points:118,565 EP
08-31-2013, 12:40 PM
Author: Lavassas, G. Nikolaidis, P. Zervas, E. Efthimiou, I.N. Doudoumis, C.C. Baniotopoulos∗ | Size: 0.85 MB | Format: PDF | Quality: Unspecified | Publisher: Engineering Structures 25 (2003) 1097–1106
[Image: 69386742777884345901.png]
In the present paper, some basic features of the analysis and the design of the prototype of a steel 1 MW wind turbine tower
are presented. The structure is 44,075 m high and has a tubular shape with variable cross section and variable thickness of the wall
along its height. The steelwork has been manufactured by steel quality S355J2G3. For the simulation of its structural response,
two different finite element models have been developed. Based on the results of the latter analyses, the design of the steel tower
for gravity, seismic and wind loadings has been performed according to the relevant Eurocodes. In particular, regarding seismic
loading, a dynamic phasmatic analysis of the tower has been carried out according to the Greek Antiseismic Code (EAK 2000).
The structure has been also checked against fatigue by applying the respective Eurocodes methodology. In the last part of the paper,
some points that concern the previous analysis and the respective design procedure are discussed in detail.
[-] The following 12 users Like TAFATNEB's post:12 users Like TAFATNEB's post
  • slowet, hapsea, gulilero, dizz, jcbv, malc, Dell_Brett, kowheng, lednar_ved, Grunf, Trishu999, subin91
  Seismic Analysis and Design of Steel Liquid Storage Tanks TAFATNEB 0 3,589 08-31-2013, 11:08 AM
  Dynamic Behaviour under Wind Loading of a 90 m Steel Chimney asim99 1 5,054 07-30-2013, 03:16 PM
Last Post: Dell_Brett
  Wind pressures and buckling of cylindrical steel tanks with a conical roof asim99 0 3,573 04-02-2013, 11:42 PM
Last Post: asim99
  Seismic & Wind analysis of bridges wafiullah 0 3,353 03-20-2011, 11:03 AM
Last Post: wafiullah
