Civil Engineering Association eBooks Journals, Papers and Presentations Dynamic Testing of Single- and Double-Story Steel-Sheathed Cold-Formed Steel-Framed S
 asim99
User ID: 9774
Threads: 476
Likes: 6,383 in 594 posts
Given Likes: 377
Points:54,091 EP
05-09-2013, 04:35 AM
Dynamic Testing of Single- and Double-Story Steel-Sheathed Cold-Formed Steel-Framed Shear Walls
Author: Iman Shamim; Jamin DaBreo; and Colin A. Rogers | Size: 2.8 MB | Format: PDF | Quality: Unspecified | Publisher: ASCE | Year: 2013 | pages: 11
This paper describes an experimental investigation of steel-sheathed cold-formed steel-framed shear walls by means of dynamic shake table tests. The objective was to evaluate the seismic performance and to identify whether the shear-wall behavior was consistent with past static tests, to obtain measures of damping and natural period of vibration, to investigate the influence of a second story, and to validate and improve the accuracy of the numerically predicted force-deformation response. The scope of study comprised five single-story and five double-story walls of the platform framing technique. Each wall was subjected to a suite of excitations: impact test to measure the linear-viscous damping ratio, harmonic excitation to estimate the natural period of vibration, and ground motions representative of the seismic hazard in Canada. An overview is presented of the test setup and dynamic loading protocols, as well as the test results and numerical model.
[-] The following 6 users Like asim99's post:6 users Like asim99's post
  • malc, Dell_Brett, blaze, ssobhan, Jackass, kowheng
  Australian Steel Institute - Steel Construction Journals adams 3 11,038 05-05-2015, 10:52 AM
Last Post: monter
  BEHAVIOUR OF STEEL SINGLE ANGLE COMPRESSION MEMBERS AXIALLY LOADED THROUGH ONE LEG asim99 1 4,681 10-15-2014, 11:00 PM
Last Post: KhaLed-S.E
  Design of Cold Formed Steel Unequel Angle Compression Members darkdkay 2 6,453 10-15-2014, 10:51 PM
  Dynamic response of bare steel concrete under human rhythmic activities TAFATNEB 0 3,640 08-14-2014, 07:39 AM
  SCI P129: Building Design using Cold Formed Steel Sections: Fire Protection ir_71 2 6,619 12-18-2013, 08:42 AM
Last Post: bigone
  Seismic retrofitting of framed structures with stainless steel TAFATNEB 0 3,386 08-31-2013, 12:29 PM
  Dynamic Behaviour under Wind Loading of a 90 m Steel Chimney asim99 1 5,052 07-30-2013, 03:16 PM
Last Post: Dell_Brett
