Soil deformation pattern around laterally loaded piles
Author: Masoud Hajialilue-Bonab, Yones Sojoudi, Habin Azarnya-Shahgoli | Size: 1 MB | Format: PDF | Quality: Unspecified | Publisher: ICE Publishing | Year: 2011 | pages: 10
In the analysis of soil–pile interaction under lateral load, the behaviour of soil around a pile is an important parameter
which has a great influence on the results. In this paper the three-dimensional deformation pattern of soil around
laterally loaded piles was studied on small-scale physical models in the laboratory using the particle image velocimetry
method. In each step of loading two digital cameras were used to capture the deformed piles and soil, one above and
the other on the side. One of the cameras was placed vertically in front of the test box and the other horizontally on top
of it. Image processing was undertaken to evaluate the three-dimensional behaviour of deformed soil. Particle image
velocimetry analysis was undertaken to obtain the displacement. The deformation pattern and shear strains of soil
around laterally loaded single pile and pile groups were studied. The effects of pile length, stiffness and diameter on the
soil deformation pattern were investigated. The group effect and interaction between piles in pile groups were also
studied. Experimental results showed that a conical passive zone is established in front of laterally loaded piles.
a- Follow the Forum Rules.
[-] The following 7 users say Thank You to asim99 for this post:
  • Evandrojr, Dell_Brett, malc, cardinal85, utan, ykhackhack, freequo
