Civil Engineering Association eBooks Journals, Papers and Presentations Optimum design of steel frames using a multiple-deme GA with improved reproduction op
 arshiakh
User ID: 37777
Threads: 100
Likes: 3,224 in 617 posts
Given Likes: 214
Points:27,526 EP
04-26-2013, 07:57 PM
Optimum design of steel frames using a multiple-deme GA with improved reproduction operators
Author: D. Safari, Mahmoud R. Maheri, A. Maheri | Size: 1.8 MB | Format: PDF | Quality: Unspecified | Publisher: Elsevier | Year: 2011 | pages: 12 | ISBN: --
In this paper, the performance of the genetic algorithm is improved by introducing some new crossover and mutation operators. The new operators are incorporated into a multiple-deme genetic algorithm in which population is divided into subpopulations and communication between different demes is established through migration of individuals, enhancing diversity and resulting in better solutions. This algorithm is applied to the minimum weight design of steel frames subjected to actual strength and ductility constraints of AISC–ASD specifications as well as other serviceability and constructability constraints. The efficiency of the proposed method is demonstrated through optimising two benchmark problems including a three-bay, three-storey steel frame and a five-bay, 22-storey special steel frame. Significant improvements in the optimum solutions are obtained with reduced number of finite element analyses, resulting in less computational effort.
[-] The following 7 users Like arshiakh's post:7 users Like arshiakh's post
  • aslam, carolinandra, kowheng, devilmaycry, malc, slowet, Jackass
  Seismic Design of Steel Special Moment Frames: A Guide for Practicing Engineers yanburak 2 4,892 08-04-2021, 08:44 PM
Last Post: Wijono
  Seismic response of steel frames containing hierarchical frictiondissipating joints TAFATNEB 1 3,652 11-28-2013, 12:08 PM
  Seismic performance of RC frames with concentric internal steel bracing arshiakh 1 4,363 11-28-2013, 12:04 PM
  Development and evaluation of improved details for ductile welded unreinforced flange arshiakh 0 2,745 08-13-2013, 09:54 AM
Last Post: arshiakh
  Self-centering post-tensioned energy dissipating (PTED) steel frames for seismic regi arshiakh 1 4,148 07-20-2013, 11:27 PM
Last Post: Jackass
  Progressive collapse design of seismic steel frames using structural optimization arshiakh 0 3,076 04-26-2013, 08:02 PM
Last Post: arshiakh
  DISPOSABLE KNEE BRACING: IMPROVEMENT IN SEISMIC DESIGN OF STEEL FRAMES asim99 0 3,159 04-06-2013, 06:44 PM
Last Post: asim99
