A necessary modification for the finite element analysis of cracked members detection
Current time: 12-16-2018, 06:41 AM
Author: asim99
Last Post: asim99
Replies 0
Views 1276
A necessary modification for the finite element analysis of cracked members detection, construction, and justification
Author: A. Ranjbaran, H. Rousta, M. O. Ranjbaran, M. A. Ranjbaran, M. Hashemi, M. T. Moravej | Size: 362 KB | Format: PDF | Quality: Unspecified | Publisher: Springer | Year: 2013 | pages: 10
The finite element analysis of cracked beam-like members is investigated. Through concise formulation,
computer implementation, and numerical experiment, the necessity for a paramount modification in
the governing differential equation is detected. In the course of numerical analysis, physical consideration,
and mathematical theory, the structure of the modification and its relation with the member geometry and
crack parameters is constructed and justified. Several new chain rules for use in the application of the method
of weighted residual to differential equations containing the derivatives of the Dirac’s delta distribution is
proposed. Through analysis of typical examples and comparison of the results with that of the others, the
accuracy, efficiency and robustness of the work are verified.
a- Follow the Forum Rules.
[-] The following 5 users say Thank You to asim99 for this post:
  • kowheng, devilmaycry, malc, Dell_Brett, civilphongvan
ConPrimer-2 Finite Element emmi 0 1,739 03-27-2015, 01:59 AM
Last Post: emmi
Dynamic Finite-Element Analysis of Jointed Concrete Pavements TAFATNEB 0 1,102 03-31-2014, 11:46 PM
FLEXURAL BEHAVIOR OF REINFORCED CONCRETE BEAMS USING FINITE ELEMENT ANALYSIS (ELASTIC TAFATNEB 0 1,315 03-31-2014, 11:22 PM
III - 1 FINITE ELEMENT ANALYSIS OF CONFINED CONCRETE COLUMNS TAFATNEB 0 1,293 03-31-2014, 11:11 PM
FINITE ELEMENT ANALYSIS OF BASE ISOLATED BUILDINGS SUBJECTED TO EARTHQUAKE LOADS TAFATNEB 1 1,520 11-20-2013, 08:25 AM
