Civil Engineering Association eBooks Journals, Papers and Presentations Brief note on the influence of shape and percentage of gravel...
 lisine
Vanuatu
User ID: 17927
Threads: 272
Likes: 11,703 in 1,304 posts
Given Likes: 4600
Points:80,767 EP
04-22-2013, 11:22 AM
Brief note on the influence of shape and percentage of gravel on the shear strength of sand and gravel mixtures
Author: Saffet Yagiz | Size: 0.124 MB | Format: PDF | Quality: Original preprint | Publisher: Bulletin of Engineering Geology and the Environment, Volume 60, Issue 4 | Year: November 2001 | pages: 321-323
The paper records the influence of the shape and the percentage of gravel on the shear strength/frictional angle of sand and gravel mixtures using direct shear tests. The shear strength is mainly derived from the frictional forces developed due to sliding and interlock; they depend on the maximum particle size and shape, the uniformity coefficient, density and the effective normal stress. As the size of material in a mixture is variable, the shear strength also depends upon the ratio of the specimen diameter to the maximum particle size. In this study, two different shapes of limestone were used, angular and rounded, and the maximum gravel size was 6.3 mm in diameter. Air-dried samples were used in the tests. It is concluded that the shape and percentage of gravel have an important influence on the shear strength properties.
[-] The following 5 users Like lisine's post:5 users Like lisine's post
  • freequo, shadabg, Dell_Brett, kowheng, malc
  How the strength properties of gravel soils depend on the type and state of the sand asim99 0 2,876 04-24-2013, 03:43 AM
Last Post: asim99
