Time history analysis as a method of implementing
Time history analysis as a method of implementing performance based design
[Image: 2i8l03r5vg6uaujfwzd8.jpg]
The current loadings code, NZS4203:1992 (Standards NZ, 1992) permits the use of time history analysis for all structures but the procedures are non-prescriptive and open to varying interpretation, particularly in the selection and scaling of time history records. Scaling of at least three records is required such that “over the period range of interest … the 5% damped spectrum of the earthquake record does not differ significantly from the design spectrum”. In practice, this has usually been interpreted so as to scale records to provide approximately the same average spectrum as the design spectrum.
[attachment=830]
[-] The following 29 users say Thank You to aslam for this post:
  • timosi™, timosi™, Dell_Brett, Dell_Brett, kowheng, kowheng, Grunf, Grunf, Administrator , Administrator , pingfan2, pingfan2, ivanveliki, ivanveliki, struceng, struceng, subin91, subin91, orambo, orambo, Thanhtung, Thanhtung, YeiYei, YeiYei, simanta, joamirose, blaze, cve_jule, rezart
Direct link:
[-] The following 12 users say Thank You to Grunf for this post:
  • blaze, melkat, malc, cve_jule, Dell_Brett, salahcivil, zrilek, David90, Nilupa, ajmf77, erthqkengnr™, ruaumoko
Just as a contribution to this (or any similar) post.
Go to
In the search box write:
It will give you all of the *.pdf documents that are stored on that site. In this particular example, there will be around 800 pdf papers.
[-] The following 5 users say Thank You to cve_jule for this post:
  • Grunf, zrilek, David90, Nilupa, erthqkengnr™
