Civil Engineering Association eBooks Journals, Papers and Presentations Model Tests on Sloshing of a Floating Roof in a Cylindrical Liquid Storage Tank Under
 mybest
Indonesia
User ID: 32155
Threads: 283
Likes: 3,957 in 566 posts
Given Likes: 686
Points:46,589 EP
06-20-2012, 09:52 AM (This post was last modified: 06-20-2012, 09:54 AM by mybest.)
Model Tests on Sloshing of a Floating Roof in a Cylindrical Liquid Storage Tank Under Seismic Excitation
Size: 1 MB | Format: PDF | Quality: Unspecified | Publisher: ASME | Year: July 27–31 2008 | pages: 9 | ISBN: 978-0-7918-4827-2
Shaking table tests are carried out to validate the analytical solutions for the sloshing of a floating roof in a cylindrical liquid storage tank under seismic excitation. The experimental tank is a 1/100 scaled model of typical oil-storage tank of 100,000m3 capacity, made of acrylic tube of 800mm in diameter. The tests are performed using three types of floating roof model: (1) a roof composed of a pontoon ring only, (2) a roof composed of uniform isotropic plate, and (3) a single-deck type roof composed of an inner deck and an outer pontoon. The motion capture system using high-speed micro cameras is employed to measure the roof displacement over the whole roof surface. The test results are compared with the analytical solutions based on linear potential theory. Overall agreement is confirmed between theory and experiment, while nonlinear bi-harmonic resonance oscillation is observed to occur in certain cases
@ssobhan
[-] The following 10 users Like mybest's post:10 users Like mybest's post
  • ykhackhack, slowet, duazo2009, zrilek, seriousboy, malc, kowheng, ssobhan, Jackass, Dell_Brett
  Dynamic interaction factors for floating pile groups arshiakh 0 3,241 09-04-2013, 04:31 AM
Last Post: arshiakh
  Seismic Analysis and Design of Steel Liquid Storage Tanks TAFATNEB 0 3,586 08-31-2013, 11:08 AM
  Seismic Response Analysis of Large Liquid Storage Tank Considering Fluid-Structure In mybest 0 4,074 06-19-2013, 10:56 AM
Last Post: mybest
  Investigation on Buckling Behavior of Cylindrical Liquid Storage mybest 0 3,753 04-11-2013, 11:33 PM
Last Post: mybest
  Wind pressures and buckling of cylindrical steel tanks with a conical roof asim99 0 3,569 04-02-2013, 11:42 PM
Last Post: asim99
  Investigation on Buckling Behavior of Cylindrical Liquid Storage Tanks Under Seismic mybest 0 3,248 03-29-2013, 12:19 PM
Last Post: mybest
  BUCKLING OF ABOVEGROUND STORAGE TANKS WITH CONICAL ROOF - Paper asim99 0 3,243 11-27-2012, 04:10 PM
Last Post: asim99
