Civil Engineering Association eBooks Journals, Papers and Presentations Behavior and Ductility of Reinforced Concrete Short Columns using Global Truss Model
 miquan
Vietnam
User ID: 631
Threads: 204
Likes: 3,748 in 387 posts
Given Likes: 1331
05-24-2012, 02:18 AM (This post was last modified: 05-24-2012, 02:20 AM by miquan.)
Author: Marina L. Moretti and Theodosios P. Tassios | Size: 1 MB | Format: PDF | Quality: Original preprint | Publisher: ACI | Year: 2006 | pages: 9
[Image: 66295842642033809948.jpg]
Abstract:
The main results of an experimental program on eight full-scale reinforced concrete short columns are presented. The specimens were subjected to compression and cyclic reversed uniaxial shear displacements. The parameters investigated were the value of shear ratio, the ratios of longitudinal and transverse reinforcement, and the normalized axial force ratio. Two different layouts of main reinforcement were tested: conventional (longitudinal) and a combination of longitudinal and bidiagonal reinforcement. Columns with shear ratio equal to 1 were shown to behave in a particularly brittle manner. The presence of bidiagonal reinforcement improved to some extent the ductility of the specimens, but not to the level required by current aseismic design. The relative performance of the specimens tested is evaluated according to various ductility criteria. A model for designing short columns is also presented.
Keywords: columns; cracking; reinforcement; shear; steel; strain
[-] The following 7 users Like miquan's post:7 users Like miquan's post
  • malc, kowheng, Jackass, zrilek, Dell_Brett, Grunf, ykhackhack
  BEHAVIOR OF FIBER-REINFORCED POLYMER (FRP) COMPOSITE PILES UNDER VERTICAL LOADS ir_71 1 6,634 06-01-2015, 05:11 PM
  DESIGN OF REINFORCED CONCRETE COLUMNS (EUROCODE 2) odiclas 0 4,468 08-26-2014, 03:02 AM
Last Post: odiclas
  A NEW MODEL FOR JOINT SHEAR FAILURE OF REINFORCED CONCRETE INTERIOR BEAM-TO-COLUMN JO TAFATNEB 0 3,863 06-01-2014, 03:35 PM
  SEISMIC RETROFIT OF REINFORCED CONCRETE BRIDGES WITH FIBER REINFORCED POLYMER COMPOSI TAFATNEB 0 4,553 04-03-2014, 12:26 PM
  FLEXURAL BEHAVIOR OF REINFORCED CONCRETE BEAMS USING FINITE ELEMENT ANALYSIS (ELASTIC TAFATNEB 0 4,936 03-31-2014, 10:22 PM
  III - 1 FINITE ELEMENT ANALYSIS OF CONFINED CONCRETE COLUMNS TAFATNEB 0 3,980 03-31-2014, 10:11 PM
  PEFORMANCE OF EXISTING REINFORCED CONCRETE COLUMNS UNDER BIDIRECTIONAL SHEAR AND AXIA TAFATNEB 0 3,962 08-27-2013, 08:45 AM
