Civil Engineering Association eBooks Journals, Papers and Presentations On the seismic noise wavefield in a weakly dissipative layered Earth
 lisine
Vanuatu
User ID: 17927
Threads: 272
Likes: 11,705 in 1,304 posts
Given Likes: 4618
04-20-2012, 09:26 AM
Author: Enrico Lunedei, Dario Albarello | Size: 1.0 MB | Format: PDF | Quality: Original preprint | Publisher: Geophysical Journal International, Vol. 177, Iss. 3 | Year: June 2009 | pages: 1001–1014
SUMMARY
Proceeding on the assumption that the seismic noise wavefield mainly consists of surface waves generated by a random distribution of independent, point-like and harmonic sources, we modelled a set of relationships that allows us to interpret empirical H/V and apparent dispersion curves in terms of the dynamic properties of a viscoelastic layered Earth. This formalization can be used to determine the effect of material damping on the expected noise wavefield in cases where the sources are relatively distant from the receivers and where the frequencies taken into account are higher than the fundamental resonance frequency of the local subsoil. Numerical experiments indicate that such effects are significant on the H/V ratio curve, whereas the apparent dispersion curve appears to be less strongly influenced by damping. This finding opens new perspectives for the use of noise measurements to infer the in situ anelastic properties of subsoil from passive seismic measurements made at the surface.
Paper + Errata
[-] The following 6 users Like lisine's post:6 users Like lisine's post
  • kowheng, mary, zrilek, Dell_Brett, melkat, sodapas
  Seismic earth pressures on retaining structures in cohesionless soils bridgeengineer 0 4,836 04-22-2016, 06:06 AM
Last Post: bridgeengineer
  Seismic earth pressures on retaining structures with cohesive backfills bridgeengineer 0 4,549 04-21-2016, 09:18 PM
  Seismic response of earth dams: some recent developments TAFATNEB 0 4,049 08-12-2014, 09:33 AM
  SEISMIC DESIGN of EARTH DAMS AND EMBANKMENTS mowafi3m 1 5,215 10-12-2013, 02:05 PM
Last Post: ssobhan
  Noise wall design guideline Design guidelines to improve the appearance of noise wall ir_71 1 5,959 04-08-2013, 12:57 PM
  Dynamic stiffness of foundation on layered soil half-space using cone frustums mybest 0 4,558 09-19-2012, 02:51 PM
Last Post: mybest
  Two- and three-dimensional bearing-capacity solutions for footings on two-layered cla wafiullah 1 4,550 08-02-2011, 11:55 AM
Last Post: Grunf
