The number 10 in Civil Engineering
Current time: 01-22-2018, 05:14 AM
Author: Grunf
Last Post: rusty
Replies 4
Views 2120
[Problem] The number 10 in Civil Engineering
Dear members,
can someone share an idea in regards to the number 10 in civil/ structural engineering. I have a task to make an educational/proffessional poster - the topic is number 10.
Any idea or interesting fact are welcome!
I was thinking on X bracing (Roman numeral is X), X cracking in walls due to earthquake, magnitude 10 on the Richter scale, crossroad X,...
Thanks in advance.
G
[-] The following 2 users say Thank You to Grunf for this post:
  • uetian19, Khaled_Elbanna
Hi,
Interesting. You can think of "DON'T" in civil/structural eingineering as well. "X" denotes dont do.
I mean Do's and Don't.
[-] The following 3 users say Thank You to visu for this post:
  • Grunf, uetian19, killerbee
Not only is the cracks path on the shear walls, but the isolines in pure tension of a prismatic body. X is also a detail for butt-welding thick plates. X, creating a union between points of a rectangle, denotes its geometric centre, or centre of mass if it is homogeneous.. In hydraulics, it is used to denote a valve. It is the double of V (roman)! Combining 2 V's we get X (><).
10 is the number of Arabic Digits, origin of contemporaneus mathmatics and the metric system. Ten is a common base to describe great numbers and the most common base for logarithmic operations after the Neplers number "e".
[-] The following 3 users say Thank You to serra for this post:
  • Grunf, farahshaheen47, Khaled_Elbanna
Dear Grunf,
How about the X for the coupling beams for walls.
ex.
[Image: 47790460799622733055_thumb.gif]
[Image: 56126831718101633302_thumb.jpg]
Diquan
[-] The following 2 users say Thank You to Diquan for this post:
  • Grunf, uetian19
some ideas:
railroad switch
[Image: 300px-Double_slip_at_Munich_central.jpg]
bridge lateral wind-bracing
[Image: 200640TS.jpg]
pylon
[Image: 800px-Ponte_estaiada_Octavio_Frias_-_Sao_Paulo.jpg]
the construction worker and engineer
[Image: 10finger.jpg]
Engineering - the Art of Neglection
[-] The following 1 user says Thank You to rusty for this post:
  • Grunf
