Civil Engineering Association eBooks Journals, Papers and Presentations Seismic Vulnerability Assessment of RC Buildings Using Hierarchical Fuzzy Rule
 melekeen
User ID: 24116
Threads: 12
Likes: 614 in 42 posts
Given Likes: 1353
03-25-2012, 03:17 PM (This post was last modified: 03-25-2012, 03:22 PM by melekeen.)
Seismic Vulnerability Assessment of Reinforced Concrete Buildings Using Hierarchical Fuzzy Rule Base Modeling
Author: Solomon Tesfamariam Assistant Professor, The University of British Columbia | Size: 330 KB | Format: PDF | Quality: Original | Publisher: Earthquake Engineering Research Institute | Year: 2010 | pages: 22
A reliable building vulnerability assessment is required for developing a risk-based assessment and retrofit prioritization. Tesfamariam and Saatcioglu (2008) proposed a simple building vulnerability module where the building performance modifiers are in congruence withFEMA 154. This paper is an extension of the building vulnerability assessment that include detailed performance modifier in congruence with FEMA 310 that is represented in a heuristic based hierarchical structure. Some of the input parameters are obtained through a walk down survey and are subject to vagueness uncertainty that is modelled through fuzzy set theory. A knowledge base fuzzy rule base modeling is developed and illustrated for reinforced concrete buildings damaged in the 1 May 2003 Bingöl, Turkey earthquake.
[Image: 78947414022389230505.png]
[-] The following 8 users Like melekeen's post:8 users Like melekeen's post
  • ibmarin, zrilek, cace-01, Dell_Brett, Jackass, oanm2000, melkat, DamaD
  Assessment of Shear Wall Building Seismic Performance by Nonlinear Analysis benny 2 12,101 08-01-2017, 09:19 AM
Last Post: abdulazizk
  Performance-based seismic assessment of skewed bridges bridgeengineer 0 4,992 04-22-2016, 06:31 AM
Last Post: bridgeengineer
  Assessment of the seismic performance of a bituminous faced rockfill dam Wolverine883 0 5,738 07-19-2015, 07:24 AM
Last Post: Wolverine883
  Responses of isolated building with MR Dampers and Fuzzy Logic TAFATNEB 0 4,930 12-28-2014, 08:57 AM
  SEISMIC VULNERABILITY ASSESSMENT USING AMBIENT VIBRATIONS: METHOD AND VALIDATION TAFATNEB 0 4,776 08-12-2014, 09:15 AM
  Specialist Meeting on the Seismic Probabilistic Safety Assessment of Nuclear Faciliti TAFATNEB 0 4,256 08-10-2014, 01:26 PM
  SEISMIC ASSESSMENT OF AN IRREGULAR THREE-STOREY FULL SCA LE RC TEST STRUCTURE WITH SU TAFATNEB 0 4,470 06-03-2014, 09:11 PM
