Civil Engineering Association eBooks Journals, Papers and Presentations Paper on Considerations in the Design and Analysis
 jamildear4u
User ID: 5529
Threads: 87
Likes: 1,063 in 108 posts
Given Likes: 145
01-07-2012, 04:59 PM
Considerations in the Design and Analysis of an ASME Section VIII, Div. 2 Reactor Support Skirt
Author: Dennis K. Williams, Trevor G. Seipp | Size: 402 KB | Format: PDF
[Image: 26425444801460855828.jpg]
This paper describes the considerations employed in the finite element analysis of a relatively “short” support skirt on a hydrocarbon reactor vessel. The analysis is accomplished in accordance with ASME B&PV Code, Section VIII, Division 2 alternate rules in conjunction with the guidelines outlined in WRC Bulletin 429. This provides a sound basis for the classification of the calculated stress intensities. The support skirt is capable of sustaining the deadweight load in addition to resisting the effects of thermal displacements, wind loadings, overturning moments from external piping loads on the attached hydrocarbon reactor vessel, and friction between the skirt base plate and concrete foundation. The displacement and thermal boundary conditions are well defined and discussed in detail. The effects of multiple scenarios for the displacement boundary conditions are examined. The skirt design also employs a hot-box arrangement whereby the primary mode of heat transfer is by radiation. A discussion of the two-part analysis is included and details the interaction between the heat transfer analysis and the subsequent structural analysis. The heat transfer finite element analysis is utilized to determine the temperatures throughout the bottom of the vessel shell and head, as well as the integrally attached support skirt. Of prime importance during the analysis is the axial thermal gradient present in the skirt from the base plate up to and slightly beyond the skirt-to-shell junction. While the geometry of the subject vessel and skirt is best described as axisymmetric, the imposed loadings are a mixture of axisymmetric and nonaxisymmetric. This combination lends itself to the judicious selection and utilization of the harmonic finite element and properly chosen Fourier series representation of the applied loads. Comparison of the thermally induced axial stress gradient results from the FEA to those obtained by the closed form beam-on-elastic-foundation are also tendered and discussed. Finally, recommendations are included for the design and analysis of critical support skirts for large, heavy-wall vessels.
The Second part of this thread i am sharing Hot-box Finite Element Analysis report using ANSYS with helping this paper, and i am sure that will help this kind of analysis.
FEA Report for HOTBOX using ANSYS
[-] The following 8 users Like jamildear4u's post:8 users Like jamildear4u's post
  • 3fan, Dell_Brett, kowheng, Jackass, malc, slowet, tluc, oanm2000
  Design Considerations for Shear Bolts in Punching Shear Retrofit of Reinforced Concre yakwetu 1 6,764 07-08-2015, 08:02 AM
Last Post: PinkPant
  Statistical considerations in network design arshiakh 0 3,622 04-08-2013, 05:51 PM
Last Post: arshiakh
  Seismic Structural Considerations asim99 0 3,642 02-02-2013, 06:08 PM
Last Post: asim99
  System Analysis of Technical Advancement in Earth Moving Equipmments - Paper asim99 0 2,810 11-26-2012, 12:39 AM
Last Post: asim99
  Fundamental Considerations For The Finite Element Analysis Of Shell Structures shadabg 0 3,927 10-11-2012, 11:23 AM
Last Post: shadabg
  TBM Design Considerations meditation 0 3,965 11-07-2009, 03:51 PM
Last Post: meditation
