Civil Engineering Association eBooks Journals, Papers and Presentations Evaluation of Concrete Cracking due to Restrained Thermal Loading and Shrinkage
 wafiullah
User ID: 24367
Threads: 28
Likes: 542 in 44 posts
Given Likes: 88
01-06-2012, 09:07 PM (This post was last modified: 05-21-2015, 01:58 PM by oanm2000.)
Author: Ulrich Häußler-Combe and Jens Hartig | Size: 2 MB | Format: PDF
In general practice, for the crack control of reinforced concrete (RC) members, reinforcement corresponding to the internal forces that lead to single cracks must be provided. This approach is extended to the cases of restrained thermal loading and concrete shrinkage, which can be considered as peculiarities of imposed loading. Therefore, an analytical model for the case of direct tension is derived as an extension of the CEB-FIP Model Code 90 and Eurocode 2 approach, which distinguishes between crack development caused by thermal loading and shrinkage and the state of crack development with single cracks and the state of stabilized cracking. Basic examples are examined to illustrate the respective characteristic properties and mutual influence of imposed deformations, crack development, and stiffness. The model is validated based on a comparison with the experimental results.
[-] The following 11 users Like wafiullah's post:11 users Like wafiullah's post
  • jcbv, lasalleguy, Dell_Brett, Jackass, kowheng, malc, avscorreia, tluc, psk62, chairatpk, ruaumoko
 aslam
Abu Dhabi
User ID: 64
Threads: 330
Likes: 7,707 in 755 posts
Given Likes: 2168
05-22-2015, 03:33 AM
[-] The following 13 users Like aslam's post:13 users Like aslam's post
  • tomtumx, concreteok, zrilek, amindoxiti, subin91, PinkPant, blaze, Dell_Brett, atram, 3fan, Pitagora, oanm2000, bridgeengineer
 Dell_Brett
Admin Deputy
Admin Deputy
Brazil
User ID: 4
Threads: 264
Likes: 19,035 in 2,188 posts
Given Likes: 42470
11-26-2020, 09:55 AM
Mirror link (direct link):
[-] The following 14 users Like Dell_Brett's post:14 users Like Dell_Brett's post
  • jcbv, carolinandra, cace-01, babakfeyzi, emmi, milova, PinkPant, zrilek, blaze, levanduy, CAMSECT, oanm2000, rami1976, gulilero
  Cause of Cracking in Post-Tensioned Concrete Box Girder Bridges and Retrofit Proced. Aviator 2 7,806 11-18-2020, 04:13 AM
Last Post: tomtumx
  Seismic Demands on Steel Braced Frame Buildings with Buckling-Restrained Braces TAFATNEB 0 6,054 10-08-2014, 02:06 PM
  Seismic Demands on Steel Braced Frame Buildings with Buckling-Restrained Braces TAFATNEB 1 5,271 11-28-2013, 12:06 PM
  Performance-based plastic design method for buckling-restrained braced frames arshiakh 1 5,670 11-28-2013, 11:58 AM
  Seismic design of steel structures with buckling-restrained knee braces asim99 1 5,054 04-06-2013, 06:49 PM
Last Post: arshiakh
  Models for flexural cracking in concrete; the state of the art gulilero 0 3,916 10-29-2012, 03:02 AM
Last Post: gulilero
  Control of Cracking in Concrete ir_71 1 6,237 10-27-2012, 08:50 AM
Last Post: mahyarov
