ACI Syposium Publications
Current time: 12-16-2018, 06:33 AM
Author: mybest
Last Post: mybest
Replies 2
Views 2511
Articles for SP-84: Earthquake Effects on Reinforced Concrete Structures -- U S Japan Research
Size: Rar 24 MB | Format: PDF | Publisher: ACI Syposium Publications
Introduction to U.S. - Japan Cooperative Earthquake Engineering Program
J. Penzien, H. Umemura, M. Watabe, and R. Hanson
Static Tests on Shear Walls and Beam-Column Assemblies and Study on Correlation Between Shaking Table Tests and Pseudo-Dynamic Tests
H. Hlralshi, S. Nakata, Y. Kltagawa, and T. Kaminosono
Construction and Instrumentation of the Full Scale Specimen
J. Wight, S. Nakata, and T. Kaminosono
Comparison Between the Reinforced Concrete Test Structure and Design Requirements from U.S. and Japanese Building Codes
J. Wight, V. Bertero, and H. Aoyama
Testing Procedure and Preliminary Test Results of a Full Scale Seven Story Reinforced Concrete Building
T. Kaminosono, S. Okamoto, Y. Kltagawa, and M. Yoshlmura
Testing, Repair and Strengthening, and Retesting of a Full Scale Seven Story Reinforced Concrete Bullding
S. Okamoto, J. Wight, S. Nakata, M. Yoshlmura, and T. Kaminosono
Inelastic Behavior of the Building
M. Yoshlmura and Y. Kurose
Analysis of the Full Scale Seven Story Reinforced Concrete Test Structure
S. Otanl, T. KabeyaSawa, H. Shiohara, and H. Aoyama
Medium Scale Wall Assemblies: Comparison of Analysis and Test Results
B. Morgan, H. Hiraishi, and W.G. Corley
Full Scale Tests of Beam-Column Joints
M. Joglekar, P. Murry, J. Jirsa, and R. Klingner
Small Scale Model Tests of Structural Components and Assemblies
B. Wallace and H. Krawinkler
Earthquake Simulation Tests of Three One-Tenth Scale Models
C. Wolfgram, D. Rothe, P. Wilson, and M. Sozen
Earthquake Simulator Tests and Associated Experimental, Analytical, and Correlation Studies of One-Fifth Scale Model
V. Bertero, A.E. Aktan, F. Charney, and R. Sause
[-] The following 21 users say Thank You to mybest for this post:
  • kowheng, faros3000, miquan, gulilero, Romanich, Dell_Brett, tluc, seriousboy, catch, Jackass, iceman84, maybc, attila, cace-01, unix0123, malc, Grunf, pedzaquino, araza023, cezar007, mahyarov
SP-9: Symposium on Creep of Concrete
Size: RAR 10 MB | Format: PDF
Creep of Concrete: Influencing Factors and Prediction
Adam M. Neville and Bernard L. Meyers
Mechanisms of Creep in Concrete
lqbal Ali and Clyde E. Kesler
Elastic and Inelastic Behavior of Hardened Mortar in Torsion
Ori lshai
Long-Time Creep-Recovery of Highly Stressed Concrete Cylinders
Frederic Roll
Analysis of Time-Dependent Behavior of Reinforced Concrete Structures
Boris Bresler and Lawrence Selna
Effect of Creep and Shrinkage on the Behavior of Reinforced Concrete Members
Adrian Pauw and B. L. Meyers
[-] The following 15 users say Thank You to mybest for this post:
  • Dell_Brett, malc, concreteok, theanhpe, blaze, ziggywas1, attila, tluc, Jackass, unix0123, gulilero, pedzaquino, araza023, cezar007, mahyarov
SP-269 Concrete: The Sustainable Material Choice
Size: 4 MB | Format: PDF | Quality: Original preprint
Performance-Based Specifications for Concrete to Advance Sustainable Development
K. H. Obla
Supplementary Cementitious Materials for Sustainability
S. Ratchye
Cementitious Blends and Their Impact on Sustainable Construction
B. Blair
Performance-Based Specifications and Sustainable Development Using Slag Cement
C.-M. Aldea, B. Shenton, and B. Cornelius
Use of Slag Cement for Improved Durability in Virginia Department of Transportation Structures
C. Ozyildirim
Achieving Sustainable Goals with Architectural Concrete
L. Rowland
Sustainable Bridges—Otay River Bridge Case Study
E. Lorenz
[-] The following 8 users say Thank You to mybest for this post:
  • pedzaquino, Jackass, araza023, Dell_Brett, tluc, attila, cezar007, mahyarov
