Civil Engineering Association Civil Engineering Resource Civil Engineering Documents Engineering Spreadsheet Elastomer Bearing Design Spreadsheet
 Dell_Brett
Admin Deputy
Admin Deputy
Brazil
User ID: 4
Threads: 264
Likes: 19,012 in 2,180 posts
Given Likes: 42439
Points:110,998 EP
09-09-2011, 05:07 AM
[Image: 85442978175986006605.jpg]
Programs (Spreadsheet) for the design of elastomer bearings.
There are two programs: one for the design of laminated bearings and other for the design of plain pad bearing. In English version, program's units are: stresses in MPa; forces in kN and dimensions in mm. Programs consider horizontal loads and rotations in longitudinal direction of structure.
DESIGN HYPOTHESIS USED IN PROGRAMS:
Laminated elastomer bearings design programs consider Euro norm standard instructions. How the results of bearing deflections may present significant variations, rotation stability is verified additionally by UIC-Code instructions and also adopted by Brazilian Standard NBR 9062 - 1985. The design of plain pad bearings consider results of Brazilian experience, complemented by EN 1337. UIC-Code an CNR (Italian Standard).
Program consider resolution of only one load condition.
Program supposes only positive vertical dead loads, positive resultant vertical loads and positive horizontal loads and displacements.
Rotations are supposed exactly with signals as given by the engineering design results.
In case of sum of rotations with opposite signals with result near zero, it is recommended consider a variation about 1,1 in major modulus rotation and 0,9 in minor modulus rotation.
The tolerance for surface leveling is 0,003 rad for pre-fabricated (steel or concrete) structures and 0,010 for cast in place structures. When bearing installation error prevision is greater than allowable tolerance, we have to add residual permanent rotation. For example, if bearing installation precision prevision under a precasted bearing is 0,010 rad, we have to consider a residual permanent rotation, in the most unfavorable sense of 0,010 rad - 0,003 rad = 0,007 rad.
No install - Direct use
[Image: homepage.png]
DIRECT LINKS thumbup
Mirror:
[-] The following 34 users Like Dell_Brett's post:34 users Like Dell_Brett's post
  • Grunf, kowheng, vsa2010, cve_jule, malc, blaze, bhawk0, aslam, joker™, oanm2000, ruaumoko, Adam Smith, sodapas, sasan7351, seriousboy, ramla2002, Diquan, orambo, David90, isurya, ting tsai huang, monter, tluc, engrezi, temporary, Gabemzaman, davegabj, portal61, draluka, david-smith, jcbv, SCREAM7890, pezhmankhan, mohcivil
  Staircase Analysis and Design Spreadsheet rami1976 4 7,563 06-25-2023, 11:19 PM
Last Post: Dell_Brett
  Spreadsheet for Design of Elastomeric Bearings for Bridges ali akbar 1 6,924 11-06-2020, 02:00 PM
Last Post: ali akbar
  38 Foundation Design spreadsheet based on ACI 318-08 portal61 2 11,434 01-17-2014, 11:42 PM
Last Post: ykhackhack
  online spreadsheet for DESIGN OF ISOLATION SYSTEM FOR BRIDGES david-smith 3 8,187 11-05-2012, 03:58 PM
Last Post: 3fan
  Band Drain Design Spreadsheet jacs127 1 7,465 05-03-2012, 01:00 PM
Last Post: shadabg
  Steel: Beam Bearing Plate Design-BRGPLT9 Ultra Zone 0 5,429 12-27-2009, 03:38 PM
Last Post: Ultra Zone
