Finite Element Study on Oil Tank Foundation System
Finite Element study on Oil Tank foundation system
Author: BUI THI YEN | Size: 4.4 MB | Format: PDF | Publisher: National University of Singapore | Year: 2005
[Image: 24799000341569728030.png]
The thesis focuses on Oil tank foundation system. The finite element code PLAXIS and PLAXIS 3D Foundation were used for the numerical simulation. The research work is aimed at pursuing the objectives: (1) Numerical analysis for single pile, pile raft analysis and compare to some other established methods to validate the FEM program (2) Back analysis of the centrifuge data of 37 end-bearing pile group underneath the sand pad supporting a model oil tank.
The research work done can be summarized as: (1) Single pile was modeled in both 2D Axisymmetry using Plaxis v8 and 3D using Plaxis 3D Foundation. The results from both analyses are compared in order to check the accuracy of Plaxis 3D Foundation program. Plaxis 3D Foundation also is validated in prediction behavior of a piled raft with 6 other established methods (2) numerical analyses to study the effect of pile cap area, thickness of overlying granular material, number of piles, and stiffness of bed layer of a pile foundation system supporting an oil tank over soft clay. The load distribution among piles, the load transfer characteristics, the maximum settlement, the differential settlement, the shape of settlement and the arching in soil are investigated in each case study. The results are compared to centrifuge data.
[-] The following 24 users say Thank You to jacs127 for this post:
  • kowheng, theanhpe, ting tsai huang, jcbv, blaze, malc, gulilero, cace-01, 3fan, Dell_Brett, oanm2000, melkat, kristoffer_89, cigutierrezg, tluc, mary, jaejeong, duazo2009, isurya, peymanlord, shadabg, huan_maivn, Quantumm, zrilek
More Links :
[-] The following 6 users say Thank You to shadabg for this post:
  • hapsea, knrsa, slowet, eliseo.as, Quantumm, uetian19
ConPrimer-2 Finite Element emmi 0 1,776 03-27-2015, 01:59 AM
Last Post: emmi
Seismic evaluation of fluid-elevated tank-foundation/soil systems in frequency domain TAFATNEB 0 1,212 05-10-2014, 09:32 AM
Dynamic Finite-Element Analysis of Jointed Concrete Pavements TAFATNEB 0 1,129 03-31-2014, 11:46 PM
III - 1 FINITE ELEMENT ANALYSIS OF CONFINED CONCRETE COLUMNS TAFATNEB 0 1,323 03-31-2014, 11:11 PM
Study on corollary of seismic base isolation system on buildings with soft storey TAFATNEB 1 1,510 11-20-2013, 07:43 AM
