CSI SAP2000 v15
CSI SAP2000 v15
[Image: 07785082511929860385.gif]
Newer Features
The following list identifies changes made to the program since the prior release:
More responsive graphical user interface, especially for the use of database tables
Real-time analysis for smaller models
Quick and easy generation of final printed reports
Predefined reports, or fully user-customized reports
Cover sheet
Formatted tables of model definition, analysis and design results
Graphical displays
Detailed design sheets
Improved automated load combinations for design
AISC 360-05/IBC2006 steel-frame design code, with seismic provisions
Direct Analysis Method of AISC 360-05 code
Includes small P-delta effect
Automated inclusion of stiffness modification factors, with user control
Design-decision guidance on when Direct Analysis Method is needed
CAN/CSA-S16-01 steel-frame design code, with seismic provisions
Enhanced design of eccentrically braced frames for AISC 360-05/IBC 2006 and CAN/CSA-S16-01 steel-frame design codes
Canadian NBCC 2005 wind loads, seismic loads, and response-spectrum functions
Load combinations can be converted to nonlinear load cases for advanced design
Enhanced display of failure modes for steel-frame design
DirectX graphics
Hyperstatic analysis for secondary prestress forces
Staged construction enhancement
Control by individual objects as well as by group
Frame end releases can be changed
Property modifiers for frames, tendons, and shells can be changed
Section properties for frames, tendons, and shells can be changed
Enhanced Section Designer
More control over material properties, including Mander model for all sections
Overlapping shapes allowed
Improved Boolean operations
Frame element fiber hinges for arbitrary sections can be defined using Section Designer
External tools developed by dealers and third parties can be accessed in SAP2000
OpenAPI functionality is complete and available without additional license
Users can add their own documents to be accessed through the SAP2000 Help menu
Export of geometry and element connectivity to CSI Perform-3D
Enhanced import of STAAD models
Installed in Windows 7 x64 using a license created by the License Generator. This post was recreated using the posts of the uploaders bellow.
[Image: Interfaz%252520Sap2000%252520v15%252520trial.jpg]
Download: Megaupload | 7 parts | English | 633MB
CSI Licence Generator Update 23-06-2011 | Megaupload | English | 341.59 KB
Moderator Note:
This is the translation of the instructions of the post above
(#2 - ingcivilpe):
Thanks Dell for the translation (hope will help someone) but i think this method including the batch file was made and every time updated by LiviuM (using a previous generator) and runing the batch file you can see all the instructions.
[Image: 18970583675053511462.gif]
I'm tired to see the same post of ingcivilpe (and every time in spanish). Excepting one post all posts of ingcivilpe are in CSI section and most of them are this License Generator or a tutorial for License Generator or both the Generator and the tutorial.
I recommend to ingcivilpe to find a new subject for posting and to stop duplicate posting (one link for post and immediately another link) and of course to stop using a foreign language. We deleted unique and good posts for not using English so no reason to accept the same used post too many times.
[-] The following 22 users say Thank You to BennyP for this post:
  • Jackass, oanm2000, vish5610, Mouh@ndiss, tremonti, zrilek, mowafi3m, jslinger, belkhedim, kaungthant, mecheil.edwar, warbeast, ramla2002, Grunf, fdgTG67, ndthanh, rezart, valinhas, engr1900, musssa, yly8, Nilupa
For requests use software requests subsection.
For software problems use software problems subsection.
For engineering problems go to Civil Engineering Discussion - Problems.
Posts in wrong section will be deleted and the user warned.
[-] The following 11 users say Thank You to BennyP for this post:
  • faros3000, vardan, oanm2000, belkhedim, mecheil.edwar, warbeast, Grunf, rezart, engr1900, yly8, Nilupa
Another Links: Stand Alone 633 MB (Installed file only)
[-] The following 10 users say Thank You to kowheng for this post:
  • zrilek, mecheil.edwar, warbeast, Dell_Brett, arceon, Grunf, diseñador, rezart, yly8, Nilupa
CSI SAP2000 v15
Mirror:
No limits to creativity
[-] The following 10 users say Thank You to joker™ for this post:
  • zrilek, mecheil.edwar, warbeast, narendra, u4406014, rezart, musssa, yly8, mybest, Nilupa
Mirror link SAP v.15 not include medecine
[-] The following 9 users say Thank You to emmi for this post:
  • mecheil.edwar, warbeast, igor1234, milvio, zrilek, snoopyy23, rezart, yly8, Nilupa
Username: SAP15
Password: BPt7u22i
Mirrors posted by Kowheng
Username and password doesnt work.
______________________________________________________________________________________________________
Moderator´s Note:
Good point, but without following the rules ... Please keep your cooperation, but within the parameters of quality required, thus avoiding warnings
[-] The following 4 users say Thank You to falconer for this post:
  • warbeast, rezart, yly8, Nilupa
CSI SAP2000 v.15.0 1.62 GB
[-] The following 17 users say Thank You to BennyP for this post:
  • warbeast, Grunf, rezart, llbb, joker™, zrilek, mowafi3m, ibg0203, tridung88, yly8, labofrock, u4406014, ChisTeam, jcbv, nickycruz, mr_ozio, Nilupa
