OFFSHORE STANDARD DNV-OS-C502 OFFSHORE CONCRETE STRUCTURES
Author: DET NORSKE VERITAS | Size: 10.7 MB | Format: PDF | Publisher: DET NORSKE VERITAS | Year: 2004 | pages: 100
[Image: 33820591124828762423.jpg]
301 The standard is applicable to Design, Construction, Inspection and Maintenance of Offshore Concrete Structures, using concrete as the structural material in the support structure as defiied in 302 below.
302 The standard can be used in the structural design of the following types of support structures:
~ GBS (Gravity Based Structures) offshore concrete structures for oil/gas production
~ GBS structures for oil/gas production with oil storage facility
~ Floating concrete structures for production of oil/gas. The structure may be of any type floating structure, i.e. Tension leg platform (TLP), Column stabilised units and Barge type units
~ Concrete harbours
~ Artificial concrete export/import harbours, either floating or fixed and with storage facilities, allowing transport of articles and goods with small boats to the artificial harbour
for reloading on large sea going vessels. Cargo may be different types or ore or oil/gas
~ Deep water caisson type concrete foundation of bridges
~ Floating foundations for bridges, parking houses or storage buildings.
303 Appendices A to F are appended to the standard. These appendices contain guidelines for the design of Offshore Concrete Structures.
304 Floating Offshore Concrete structures shall be designed with freeboard and intact stability in accordance with DNVOS-
C301. For temporary phases the stability shall be in accordance with DNV Rules for Planning and Execution of Marine Operations.
305 The development and design of new concepts for Offshore Concrete Structures requires a systematic hazard identification process in order to mitigate the risk to an acceptable risk level. Hazard identification is therefore a central tool in this standard in order to identiSl hazards and mitigate these to an acceptable risk level.
[-] The following 12 users say Thank You to ir_71 for this post:
  • kowheng, seriousboy, Dell_Brett, malc, ssobhan, blaze, dede, Umer.Aleem, zrilek, isurya, Jackass, lednar_ved
Here is link for download all dnv standards:
Size: 1 MB | Format: PDF
DIRECT LINKS thumbup
[-] The following 6 users say Thank You to hans01 for this post:
  • Dell_Brett, malc, blaze, aidil01, zrilek, chenamoy
JSCE Standard Specifications for Concrete Structures - Materials and Construction ir_71 1 1,912 06-10-2013, 07:10 AM
Last Post: bigone
JSCE Standard Specifications for Concrete Structures ir_71 1 1,970 06-10-2013, 07:07 AM
Last Post: bigone
OFFSHORE STANDARD DNV-OS-C503 CONCRETE LNG TERMINAL STRUCTURES AND CONTAINMENT SYSTEM ir_71 0 1,753 06-17-2011, 02:40 PM
OFFSHORE STANDARD DNV-OS-C105 STRUCTURAL DESIGN OF TLPS (LRFD METHOD) ir_71 0 1,603 06-17-2011, 02:27 PM
