OFFSHORE STANDARD DNV-OS-C503 CONCRETE LNG TERMINAL STRUCTURES AND CONTAINMENT SYSTEM
OFFSHORE STANDARD DNV-OS-C503 CONCRETE LNG TERMINAL STRUCTURES AND CONTAINMENT SYSTEMS
Author: DET NORSKE VERITAS | Size: 5.8 MB | Format: PDF | Publisher: DET NORSKE VERITAS | Year: 2004 | pages: 58
[Image: 22249567797275019998.jpg]
301 The standard is applicable to LNG Export and Import Terminal Structures using concrete as the structural material in the support structure as defined in 302 and 303 below.
302 LNG Export Terminal Structures LNG export terminals are, by nature, located near the coast and are designed to liquesl the natural gas which will then be loaded onto LNG carriers. An LNG export terminal generally includes: an incoming natural gas metering and receiving station, including in the case of a two phase incoming pipeline, a slug catcher condensate stabilisation and storage gas treatment units in which any acid gases, water, heavier hydrocarbons and, if appropriate, mercury which might be present in the incoming gas are extracted liquefaction units which produce LNG and within which, ethane, propane, commercial butane, heavier hydrocarbons and nitrogen can be extracted. A proportion of the extracted hydrocarbons can be used as refrigerant make up. A liquefaction unit uses very specific equipment such as cryogenic spool-wound or brazed plate-fin exchangers and high-powered turbo compression units. Two refrigerant cycles in cascade are usually employed LNG storage tanks and the relevant loading plants for filling LNG carriers generation andor purchase and distribution of the utilities necessary for the plant to operate (electricity, steam, cooling water, compressed air, nitrogen, fuel gas etc.) general off-site installations, (gas and liquid flare systems, effluent treatment, fiie fighting systems etc.). Most of the gas treating steps can be commonly found in gas treatment plant for the production of sales gas. e.g. acid gas removal, dehydration, hydrocarbon dew point and liquid natural gas (LNG) recovery.
303 LNG Import Terminals
LNG import terminals are designed to receive LNG from LNG carriers, to unload, store and convert it into the gaseous phase for sending it out to the gas network or gas consumers. Thus an LNG receiving terminal provides several essential functions which are:
~ unloading
~ storage
~ LNG recovery and pressurising
~ vaporising
~ gas quality adjustment.
304 Appendices A-D are appended to the standard. These appendices contain guidelines for the design of Terminals in accordance with approach for Land LNG Terminal Structures in accordance with the approach used for the design of Land LNG Terminal Structures modified with the environmental condition of an offshore terminal.
305 The standard is combining the design and construction experience from the fixedfloating offshore structures DNVOS- C502, DNV Rules for Classification of Ships Pt.5 Ch.5, IMO - IGC Code “the International Code for the Construction and Equipment of Ships Carrying Liquefied Gases in Bulk” and the experience from design and construction of land based storage tank for LNG as presented in EN-1473 andNFPA 59A.
306 For the detailed design of primary steel containment tanks reference is made to Rules for Classification of Ships Part 5 Chapter 5, IGC- IMO Code, EN-1473 and NFPA 59A. See Appendices C “General Design Principles LNG Containment Structures” and D “Detailed Structural Design of Containment System” for Guidelines for the design of the primary steel containment tanks in accordance with conventional tanks at land. The environmental impact on offshore terminals are included in these guidelines.
307 On ships, the IGC-IMO type B independent tanks are widely used. These tanks are designed, constructed and inspected in accordance with the requirements in the IGC - IMO Code. The DNV Rules for Classification of Ships Part 5 Section 5 gives detailed requirements for the design of Independent tanks Type B. Site specific data shall be considered in the design of Terminal Structures and Containment Systems.
308 The development and design of new concepts for LNG terminals requires a systematic hazard identification process in order to mitigate the risk to an acceptable risk level. Hazard
identification is therefore a central tool in this standard in order to identiSl hazards and mitigate these to an acceptable risk level.
[-] The following 9 users say Thank You to ir_71 for this post:
  • kowheng, seriousboy, Dell_Brett, malc, Jackass, blaze, Umer.Aleem, zrilek, jaejeong
JSCE Standard Specifications for Concrete Structures - Materials and Construction ir_71 1 1,911 06-10-2013, 07:10 AM
Last Post: bigone
JSCE Standard Specifications for Concrete Structures ir_71 1 1,966 06-10-2013, 07:07 AM
Last Post: bigone
OFFSHORE STANDARD DNV-OS-C502 OFFSHORE CONCRETE STRUCTURES ir_71 1 2,191 06-17-2011, 03:49 PM
Last Post: hans01
OFFSHORE STANDARD DNV-OS-C105 STRUCTURAL DESIGN OF TLPS (LRFD METHOD) ir_71 0 1,602 06-17-2011, 02:27 PM
