Civil Engineering Association eBooks Structural Books Steel SCI P103: Electric lift installations in steel frame buildings
Points:178,871 EP
05-04-2011, 03:22 AM
Author: R G 0GDEN | Size: 2.9 MB | Format: PDF | Publisher: SCI | Year: 1994 | pages: 72 | ISBN: 185942 0141
[Image: 53215184579903474386.jpg]
Lift installations in steel frame buildings are conventionally supported either directly by the steel frame, or by concrete floors which in turn transmit the loading onto the frame. Whilst the frame and lift installation are separate and distinct packages, the detail of each can have a significant effect on the cost, buildability, programming and performance of the other.
This publication is the result of a joint initiative from the UK lift and steel industries. It continues a programme of research initiated by the Steel Construction Review and carried out by The Steel Construction Institute into building interfaces. It incorporates the studies on the interface requirements of standard lift installations, carried out by The National Association of Lift Makers (NALM) through the NALM Forum.
The publication provides an overview of standard electric lift installations of the type normally used in steel frame buildings. It appraises and recommends various methods of attaching guide rails, landing doors and other items of lift equipment to the building. The document also recommends acceptable guide rail spans for lifts of various speeds, deflection limits for guide rails and their supporting structure and design loads for structural elements supporting the lift installation. It provides a basis for standardising key design details, and where necessary will assist building designers to develop structural components and construction details in advance of a lift supplier being appointed.
The publication is written for use by architects, engineers, steelwork contractors, lift engineers, site managers, clients and developers.
[-] The following 21 users Like ir_71's post:21 users Like ir_71's post
  • kowheng, knrsa, seriousboy, malc, blaze, Dell_Brett, Jackass, ziggywas1, oanm2000, jferrer, nowanda, sodapas, baikur, zrilek, narendra, monter, kmmh76, mahyarov, tang1942, gulilero, bigone
 andersen3
User ID: 464
Threads: 54
Likes: 6,117 in 996 posts
Given Likes: 1243
Points:29,008 EP
11-15-2012, 04:20 PM (This post was last modified: 11-16-2012, 12:11 AM by Dell_Brett.)
all links dead; mirror:
Post Edited by Moderator
[-] The following 4 users Like andersen3's post:4 users Like andersen3's post
  • gulilero, Trishu999, pfaa2020, bigone
 bigone
User ID: 4505
Threads: 92
Likes: 5,722 in 517 posts
Given Likes: 7145
Points:24,374 EP
12-18-2013, 12:24 PM
SCI_P103 Electric lift installations in steel frame buildings_1994-185942 0141.pdf
[-] The following 6 users Like bigone's post:6 users Like bigone's post
  • usman, ting tsai huang, Dell_Brett, concreteok, PinkPant, Veggeta
  Steel Frame Design Examples febo927 1 1,510 05-28-2018, 01:57 PM
  SCI P397: Elastic design of single-span steel portal frame buildings to Eurocode 3 Dobblo 0 1,411 05-13-2016, 12:35 PM
Last Post: Dobblo
  Steel frame design - lecture bashir999 3 3,627 11-13-2014, 02:10 AM
Last Post: stlooi
  Advanced Analysis in Steel Frame Design - Guidelines for Direct Second-Order Inelasti asim99 1 1,814 07-07-2014, 03:08 AM
Last Post: i_kabir
  Recommended Seismic Design Criteria for New Steel Moment-Frame Buildings asim99 0 1,368 01-16-2013, 12:47 AM
Last Post: asim99
  Eurobuild in Steel - Comparison of the Design of a Portal Frame ir_71 1 2,195 11-22-2012, 05:50 AM
  Design of Portal Frame Buildings Dell_Brett 4 5,223 07-24-2012, 06:30 AM
Last Post: shadabg
