Civil Engineering Association Civil Engineering Resource Civil Engineering Documents Engineering Spreadsheet Foundation: Assessment of Transversely Loaded Pile in Soil
Likes: 33,527 in 2,936 posts
08-06-2009, 02:58 PM (This post was last modified: 12-10-2010, 12:08 AM by usman.)
[Image: 25395600701110512988.jpg]
.xls   Horiz loading on piles(Cohesionless).xls (Size: 49 KB / Downloads: 575)
[Image: 97000283121349221555.jpg]
.xls   Horiz loading on piles(Cohesive).xls (Size: 54.5 KB / Downloads: 635)
[-] The following 51 users Like kowheng's post:51 users Like kowheng's post
  • Dell_Brett, Dell_Brett, bangch, bangch, rendel_©, rendel_©, robertsas, robertsas, abudabeeja, abudabeeja, aslam, aslam, hsccindia, hsccindia, isurya, isurya, ildar, ildar, ggg1, ggg1, zrilek, zrilek, Nedian, Nedian, tonmjr, tonmjr, oram, phat2505, psiglos, JAVA, chenamoy, Chillpill, Vincwilson, theanhpe, Gabemzaman, relu59, Galileo, simanta, deanz_75, amira, aleph177, Batman07, joamirose, zainseiya, bhuiyan, malc, Yuma, uetian19, ykhackhack, bigone, spat
 SUSheikh
User ID: 4351
Threads: 8
Likes: 33 in 6 posts
Given Likes: 22
01-23-2010, 07:32 AM (This post was last modified: 01-23-2010, 08:12 AM by SUSheikh.)
hi Kowheng.
I just wanna ask your how do u design piles that have horizontal load. ( for an example bore pile. )How do i take the moment from horizontal load. any simplified method by hand calculation.Doesnt it involve soil and structure interaction?
Thank You
Hi
Another thing. the moment can be uniform all the way to the bottom.
thanks
01-23-2010, 08:46 AM
Hi SUSheikh,
It's very hard for me to explain because your question show that you don't have basic for laterlal load pile design. I recommend you to read "Pile Foundation Analysis and Design, Poulos Davis, Chapter 7" where all formula in my worksheet is reference to.
After reading and look into formula in worksheet, then we can discuss more specifically.
Teaching & explain like a teacher is very very hard work for me. Sorry for that.
[-] The following 6 users Like kowheng's post:6 users Like kowheng's post
  • zrilek, SUSheikh, davegabj, deanz_75, aleph177, bigone
 Dell_Brett
Admin Deputy
Admin Deputy
Brazil
User ID: 4
Threads: 264
Likes: 19,035 in 2,188 posts
Given Likes: 42464
01-23-2010, 09:12 AM
The complete book could be found at:
[-] The following 5 users Like Dell_Brett's post:5 users Like Dell_Brett's post
  • kowheng, zrilek, SUSheikh, ykhackhack, bigone
 SUSheikh
User ID: 4351
Threads: 8
Given Likes: 22
01-24-2010, 03:40 PM
hi Kowheng
I have briefly read through the Pile Foundation Analysis and Ciria Report 103. Since my pile is 35m in length so it is considered to be a long pile. Hence, the mode of failure would be dependent on the yield moment of the pile.Therefore it is safe to assume that the reinforcement together with the section properties of the pile must give an equal capacity to the yield moment.
In my case i have a horizontal force of 562.5KN (SLS) and 1.4*562.5kN= 787.5kN
e= 6000mm and size of pile d=1000mm. cu assume to 25 kN/m2 .
By using Figure 7.9 in the book u recommend . i obtained the ultimate lateral resistance in cohesive soil=31.5. Then using the figure 7.9 i obtain yield moment (Mu/cuD3)= 250
and I obtained Mu ( Yield Moment to be 6250kNm). Based on this moment then i designed the reinforcement for my bored pile in order to cater to the lateral load (H=562.5kN). The axial load will be looked into separately. Do u think this approach is correct? Thanks alot for ur help. I also appreciate u recommending me the book on pile.:yes:
01-24-2010, 04:12 PM (This post was last modified: 01-24-2010, 04:14 PM by kowheng.)
Hi SUSheikh,
You are welcome.
In Hu design, we use factor load, not SLS load.
When consider Hu, we have to explicitly consider Hu per pile or total Hu per footing. Your approach is correct. I'd used this approach to design piles of bridge abutment for 20m steel I girder span to resist lateral seismic force in Solomon Island (4 years ago) and 2000ton anchor bed for pretensioned casting yard 15 years ago. It's still there and working well until now.
[-] The following 1 user Likes kowheng's post:1 user Likes kowheng's post
  • SUSheikh
 SUSheikh
User ID: 4351
Threads: 8
Given Likes: 22
01-24-2010, 04:31 PM
Hi Kowheng.
I am using Hu to be ULS not SLS. I do understand the formula in the book. But i wish u could explain a bit more on your spreadsheet. In my case i'm on interested to obtain the bending moment generated by the lateral load. what i can gather is that ur ploting the behaviour of the pile.
anyhow. Thanks A lot.
Best Regards
SUSheikh
[-] The following 2 users Like SUSheikh's post:2 users Like SUSheikh's post
  • Gabemzaman, cristi
  Foundation: Prestressed Concrete Pile Design kowheng 14 30,244 05-23-2012, 10:22 AM
  Foundation: Lateral Pile Analyis with PY Curves and Non-Linear Pile Properties mskhaled 4 11,678 01-01-2011, 11:02 AM
Last Post: ravisbassi
  Foundation: Characteristic Load Method of Analysis for Laterally Loaded Piles robertsas 1 7,107 12-04-2010, 06:06 AM
Last Post: usman
  Foundation: Pile Group Analysis - PILEGRP Ultra Zone 0 6,863 01-02-2010, 01:05 AM
Last Post: Ultra Zone
  Foundation: Hiley's Pile Driving Formula kowheng 2 13,603 08-28-2009, 07:49 AM
