Civil Engineering Association eBooks Journals, Papers and Presentations Self-Compacting Concrete (SCC) for Prestressed Bridge Girders
Points:178,871 EP
03-15-2011, 06:38 AM
Author: Bulent Erkmen, Carol K. Shield, Catherine E. French | Size: 4.16 MB | Format: PDF | Publisher: University of Minnesota | Year: 2008 | pages: 347
[Image: 63202725973066810364.jpg]
Researchers conducted an experimental program to investigate the viability of producing self-consolidating concrete (SCC) using locally available aggregate, and the viability of its use in the production of precast prestressed concrete bridge girders for the State of Minnesota. Six precast prestressed bridge girders were cast using four SCC and two conventional concrete mixes. Variations in the mixes included cementitious materials (ASTM Type I and III cement and Class C fly ash), natural gravel and crushed stone as coarse aggregate, and several admixtures. The girders were instrumented to monitor transfer length, camber, and prestress losses. In addition, companion cylinders were cast to measure the compressive strength and modulus of elasticity, and to monitor the creep and shrinkage over time. The viability of using several test methods to evaluate SCC fresh properties was also investigated. The test results indicated that the overall performance of the SCC girders was comparable to that of the conventional concrete girders. The measured, predicted, and calculated prestress losses were generally in good agreement. The study indicated that creep and shrinkage material models developed based on companion cylinder creep and shrinkage data can be used to reasonably predict measured prestress losses of both conventional and SCC prestressed bridge girders.
  • kowheng, knrsa, blaze, melkat, malc, Dell_Brett, usman, lamkin, sujups, diotviet, Jackass
  Precast/Prestressed Concrete Institute Publications rendel_© 12 16,636 10-13-2013, 02:00 PM
Last Post: milova
  Self-compacting Concrete in Bridge Construction ir_71 0 3,672 07-11-2013, 07:44 AM
  COMPARIISON OF R.C.C. AND PRESTRESSED CONCRETE CIIRCULAR WATER TANKS aslam 0 3,498 03-23-2013, 05:38 AM
Last Post: aslam
  Optimized Sections for High-Strength Concrete Bridge Girders—Effect of Deck Concrete ir_71 1 5,740 03-02-2013, 05:08 AM
Last Post: arshiakh
  A NEW DESIGN METHOD FOR PRESTRESSED CONCRETE CONTINUOUS FLAT SLABS asim99 0 4,181 11-28-2012, 09:45 PM
Last Post: asim99
  Self Compacting Hybrid Fiber Reinforced Concrete Composites for Bridge Columns kowheng 0 4,146 05-27-2012, 04:46 AM
  Materials and Methods for Corrosion Control of Reinforced and Prestressed Concrete St ir_71 0 3,678 07-08-2011, 04:12 PM
