Civil Engineering Association eBooks Journals, Papers and Presentations Recent research developments in stability and ductility of steel bridge structures
 yanburak
User ID: 27551
Threads: 93
Likes: 821 in 94 posts
Given Likes: 421
Points:9,150 EP
11-23-2010, 08:15 AM
Journal of Constructional Steel Research
Volume 55, Issues 1-3, July 2000, Pages 183-209
Abstract
Some ductility and strength researches of thin-walled steel bridge structures recently conducted at Nagoya University are summarized in this paper. The first part is on the investigations of the behavior of component plates, which are subjected to compression or shear. Both the monotonic and cyclic loading conditions have been considered. Then the studies of stub-columns under combined action of compression and bending are presented. The considered stub-columns are composed of stiffened and unstiffened box sections or pipe sections. For both the plates and stub-columns, empirical equations of strength and ductility have been developed. Based on the equations, a simple ductility evaluation method for thin-walled steel structures which involves a nonlinear pushover analysis and a definition of failure criterion is finally proposed. Moreover, some recent results of thin-walled structures through cyclic experimental and numerical studies are also included in this paper and are compared with the ductility estimations through the proposed simple method.
Author Keywords: Cyclic loading; Ductility; Initial deflection; Local buckling; Residual stresses; Stability; Stub-column; Thin-walled structure; Ultimate strength
[-] The following 5 users Like yanburak's post:5 users Like yanburak's post
  • kowheng, Dell_Brett, ilgar, kmmh76, usman
  Journal: Steel Construction, Design and Research struceng 6 9,997 08-30-2015, 09:39 PM
Last Post: hodzicemir
  Seismic response of earth dams: some recent developments TAFATNEB 0 2,831 08-12-2014, 09:33 AM
  AISC RESEARCH ON STRUCTURAL STEEL TO RESIST BLAST AND PROGRESSIVE COLLAPSE TAFATNEB 0 2,830 10-22-2013, 06:40 PM
  SEISMIC LATERAL FORCE DISTRIBUTION FOR DUCTILITY-BASED DESIGN OF STEEL PLATE SHEAR WA TAFATNEB 0 3,203 08-31-2013, 10:41 AM
  Recent research advances on the dynamic analysis of composite shells: 2000–2009 asim99 0 2,868 04-19-2013, 06:13 PM
Last Post: asim99
  Seminar on Steel Structures: DESIGN OF COLD-FORMED STEEL STRUCTURES ir_71 1 4,821 04-08-2013, 05:28 AM
  Journal of Constructional Steel Research - Papers lisine 4 7,469 03-23-2013, 12:01 PM
Last Post: ssobhan
