Interesting links
Dear Admin and Moderators,
It's a good idea open possibility to post interesting and curious links about structures (in general). I'm not referring a existing "Famous Projects" forum.
If yes, where is the best place?
The idea is put links like:
[-] The following 9 users say Thank You to Dell_Brett for this post:
  • aslam, aslam, Grunf, Grunf, moh_towhid, moh_towhid, oanm2000, oanm2000, jonev
I can't use words to describes these pics but i can't be sure of failure modes of the structure.
Can we have some opinions here or should i open up a new thread in open discussion?
concrete solution advocate
[-] The following 3 users say Thank You to concreteok for this post:
  • Grunf, Grunf, jonev
There is no damage to superstructure. Also there is no damage to raft. Piles are broken. I think the cause of failure is DIFFRENTIAL SETTLEMENT. Lac of proper soil investigation.
[-] The following 4 users say Thank You to aslam for this post:
  • Grunf, Grunf, mnovo, jonev
@dell Brett: excellent idea!
It would be a great thing to start a new topic involving the interesting structures, their construction, as well as their collapse, just as would be great to comment all the images/ links/ and videos related to the above mentioned structures.
G
[-] The following 1 user says Thank You to Grunf for this post:
  • jonev
Aslam,
u thk any truth to one of the comment in the web that broken piles do not have exposed reinforcement due to its prestressed nature?
[-] The following 1 user says Thank You to concreteok for this post:
  • jonev
The problem was that they were excavating soil from beneath the building to make sublevel with garages. Very stupid idea. I think the building then stood only on piles and they broke.
[-] The following 5 users say Thank You to ivanveliki for this post:
  • Grunf, Grunf, Dell_Brett, Dell_Brett, jonev
Other pictures can be found here:
[-] The following 6 users say Thank You to Dell_Brett for this post:
  • Grunf, Grunf, amaranu, amaranu, oanm2000, oanm2000
If the structure rotated about a point, then it is design issue regarding pile foundation as that will mean local failure of piles and so there was rotation. If the structure footprint shifted, that means there was small side movement before collapse, then I think it would be excavation well below pile cap, with lateral forces shearing piles and then collapse. That is my guessing from the pictures.
Thanks
[-] The following 2 users say Thank You to Solution for this post:
  • amaranu, amaranu
