Civil Engineering Association Civil Engineering Resource Civil Engineering Documents Engineering Spreadsheet Steel Beam Allowable End Reaction
 usman
User ID: 59
Threads: 138
Likes: 6,571 in 671 posts
Given Likes: 4974
11-11-2010, 10:45 PM
[Image: 90563765487441948031.jpg]
Spreadsheet program written in MS-Excel for the purpose of determining the allowable beam end reaction and the allowable end moment for the purpose of end connection design.
It uses the database of member dimensions and section properties from the "AISC Shapes Database", Version 3.0 (2001) as well as the AISC 9th Edition (ASD) Manual (1989).
W, S, M, C, and MC shapes may be selected.
It utilizes the procedure which a steel fabricator would typically use to determine end connection design loads when end reaction values are not specified on the design and construction drawings by the engineer. This procedure is based on the AISC 9th Edition (ASD) Manual (1989) Allowable Uniform Load Tables on pages 2-36 to 2-140 and AISC Specification Chapter K, pages 5-80 and 5-81.
Contains “comment boxes” which contain a wide variety of information including explanations of input or output items, equations used, data tables, etc.
130KB XLS
[-] The following 14 users Like usman's post:14 users Like usman's post
  • ilgar, jupe01, robertsas, kowheng, RAULVB, malc, ravisbassi, Dell_Brett, Quantumm, goober, duazo2009, tremonti, hcardenas, Umer.Aleem
  Spreadsheet for Pile's reaction in group camto2 0 5,782 03-18-2018, 02:31 PM
Last Post: camto2
  Steel: Crane Beam Design Dell_Brett 3 14,159 12-17-2015, 10:48 PM
Last Post: scorpion07
  Steel Beam Design usman 0 5,568 12-03-2010, 12:25 AM
Last Post: usman
  Steel Beam Design - Beam Selection Tables usman 0 5,745 12-02-2010, 12:42 AM
Last Post: usman
  Steel Beam Column Design usman 0 5,074 12-02-2010, 12:30 AM
Last Post: usman
  Steel Beam Web Stiffener Analysis usman 0 7,767 11-13-2010, 06:25 PM
Last Post: usman
  Steel Beam and Column Analysis and Code Check usman 0 6,542 11-13-2010, 06:18 PM
Last Post: usman
