Civil Engineering Association Civil Engineering Resource Civil Engineering Documents Engineering Spreadsheet Steel Beam and Column Analysis and Code Check
 usman
User ID: 59
Threads: 138
Likes: 6,571 in 671 posts
Given Likes: 4974
Points:35,696 EP
11-13-2010, 06:18 PM
[Image: 45340334506704641598.jpg]
[Image: 31471927006329738525.jpg]
[Image: 40802103944348991370.jpg]
[Image: 14752332784304485658.jpg]
[Image: 19741251399847701154.jpg]
Spreadsheet program written in MS-Excel for the purpose of analysis and code checking of steel beams and columns. Specifically, beams and columns are analyzed / code checked per the AISC 9th Edition Allowable Stress Design (ASD) Manual. Both actual and allowable stresses are computed, with the final result being a computed "stress ratio" of actual stress/allowable stress. Also, a list of the lightest weight members which satisfy the code check is displayed for convenience.
- Analysis / Code Check for W, S, M, and HP Shapes
- Analysis / Code Check for Non-Database and Built-Up Shapes
- Analysis / Code Check for Channel Shapes
- Analysis / Code Check for Rectangular HSS (Tube) Shapes
- Analysis / Code Check for Round HSS and Pipe Shapes
826KB XLS
[-] The following 20 users Like usman's post:20 users Like usman's post
  • chigozie, Dell_Brett, jcbv, ruaumoko, strengr, kowheng, ravisbassi, ziggywas1, robertsas, narendra, lasalleguy, goober, Quantumm, tremonti, garcia2010, hcardenas, zainseiya, Alexander, malc, tolesa54
  Steel: Crane Beam Design Dell_Brett 3 12,836 12-17-2015, 10:48 PM
Last Post: scorpion07
  RC Beam Capacity Check knrsa 1 8,803 04-03-2014, 02:19 PM
Last Post: arshiakh
  Concrete Short Column Analysis and Design - EC BennyP 2 9,674 08-24-2013, 11:23 AM
Last Post: pezhmankhan
  Estimating Fire Resistance Time of Steel Beam and Column Protected by FP Insulation portal61 0 4,301 11-27-2011, 05:07 AM
Last Post: portal61
  Steel: Monorail Beam Analysis-MONORAIL Ultra Zone 1 8,504 01-11-2011, 03:51 PM
Last Post: surajdas
  Analysis: Single Span and Continuos Beam Analysis - BEAMANAL Ultra Zone 2 7,183 12-15-2010, 06:52 PM
Last Post: usman
  Steel Beam Design usman 0 4,795 12-03-2010, 12:25 AM
Last Post: usman
