BEHAVIOR AND PERFORMANCE OF STEEL MOMENT-FRAMED BUILDINGS SUBJECT TO DYNAMIC COLUMN L
BEHAVIOR AND PERFORMANCE OF STEEL MOMENT-FRAMED BUILDINGS SUBJECT TO DYNAMIC COLUMN LOSS SCENARIOS
By
SETH TUCKER HOFFMAN
THESIS
M.Sc. Civil Engineering
Gradutae College
University of Illinois at Urbana-Champaign 2010
Adviser:
Assistant Professor Larry Alan Fahnestock
ABSTRACT
Progressive or disproportionate collapse occurs when localized structural damage leads to widespread collapse or failure of a structure. Although the loss of any structural component in a building has the potential to initiate progressive collapse, structural columns in steel buildings are particularly susceptible to initiating this behavior if their load-carrying capacity is compromised. Steel-framed buildings can possess the capacity to bridge over a single lost column and arrest collapse, but the dynamic and three-dimensional nature of this event prevents simple design-based analysis approaches from providing accurate assessments of collapse resistance.
This research employed a set of two prototype steel moment-framed buildings to study dynamic ground-level column-loss scenarios for a variety of column locations within the structures. One building contained three stories while the other had ten. Both were intended to be representative of typical perimeter moment-frame office buildings built in a low-seismic region of the United States. Three-dimensional finite element models were constructed to model the buildings using shell elements and incorporating the steel deck and composite concrete slab floor system. Nonlinear material models were used along with simplified component models for beam and girder connections. Accurate structural and non-structural masses were used to capture realistic inertial effects. The models were then analyzed using the Abaqus/Explicit finite element analysis engine to simulate instantaneous structural loss of a single ground-level column. This analysis was carried out for twelve individual columns in the three-story building and four individual columns in the ten-story building. Analysis was conducted for a sufficient time following column loss to assess structural collapse or obtain the peak vertical displacement if collapse was arrested. The output was then post-processed to obtain stresses in the steel deck and concrete slab as well as resultant connection forces and load-redistribution behavior.
The three and ten-story building were found to be capable of arresting collapse following the loss of an individual ground-level supporting column for most column locations. Demands were the least severe for perimeter columns within a moment frame, but the structures were also able to bridge over lost interior columns that had no moment connectivity. Connection demands were significant in most column-loss scenarios and adequate moment connection strength and ductility was found to be necessary to ensure successful collapse arrest.
[-] The following 4 users say Thank You to JUANCM for this post:
  • kowheng, Dell_Brett, fer962933, rezart
SEISMIC BEHAVIOR OF DAMAGED BUILDINGS: A COMPARISON OF STATIC AND DYNAMIC NONLINEAR A TAFATNEB 0 985 08-10-2014, 03:06 PM
Evaluation of the seismic performance of a three-story ordinary moment-resisting conc TAFATNEB 0 1,115 04-26-2014, 07:25 PM
Dynamic analysis of buildings for earthquake- resistant design TAFATNEB 0 1,543 12-20-2013, 01:19 PM
Dynamic behavior of masonry structures under pyroclastic flows TAFATNEB 0 932 11-02-2013, 02:06 PM
Seismic retrofitting of framed structures with stainless steel TAFATNEB 0 1,131 08-31-2013, 01:29 PM
