Civil Engineering Association Software Software Product Non Engineering Software Folder Lock
Folder Lock
06-17-2009, 06:43 AM (This post was last modified: 10-12-2013, 10:49 PM by LiviuM.)
Folder Lock 6.1.3 Final
INFO:
Folder Lock™ is a fast data encryption and password protection software for Windows. It can simultaneously encrypt, lock and password protect your files, folders, drives, USB drives and even CD/DVD-RW.Folder Lock creates encrypted storages called 'Lockers'. You can keep as many of your private files & folders in your Locker and password protect it with a single click. You can transfer, secure and backup these Lockers. Lockers are portable, you can keep them in USB Flash Drives, CD/DVD (R-RW), & notebooks or transfer them via email or upload. Lockers are even undeletable on the computer where Folder Lock is installed.
Just as Lockers in physical world, different users can create their own Lockers. A single user can create multiple Lockers with different passwords as well. With Folder Lock, you can choose either to encrypt using 256-bit AES on-the-fly encryption or lock files, folders and drives anywhere on your computer. Each Locker can contain your encrypted files as well as your personal list of locked items.Furthermore, Folder Lock's options like hack monitoring, stealth mode, data shredding, history cleaning, auto protection, portable USB autoplay feature & virtual keyboard can enhance data security beyond anything ever achieved. In addition, a locker's delete, move and rename are password protected to prevent data loss.Folder Lock is compatible on 32-bit versions of Windows Vista / 2003 / XP / 2000 & is the most downloaded File Security program in the market.
Features and Benefits:
• On-the-fly 256-bit AES encryption (military standard) for data security.
• All Important files & folders protected in one place for easy backup.
• Folder Lock offers full portability. Save your Lockers in CD/DVD or USB Drives.
• Lockers are transferable and can be emailed or uploaded.
• Lockers are undeletable on the PC where Folder Lock is installed. Deletion requires you to login into Folder Lock.
• Shred files feature can secure delete original data when files & folders move to a Locker.
• Stealth Mode feature can efficiently hide all the traces of Folder Lock ever been installed on your PC.
• Removes traces like recent document history, find files history & copy/clipboard data everytime Locker closes.
• Files and folders can be encrypted and locked simultaneously for added security.
• Fast! Data once encrypted is later decrypted in memory, preventing data recovery & slow processing.
• Whether it's privacy, data theft, loss, leaks or intrusion attacks. Folder Lock secures your data in one fell swoop.
Latest Folder Lock Version 6.1.3, Released on January 1st, 2009:
New kernel level functions and multiple protection procedures added in the core functionality of the product. This version fixes previous glitches and improves performance.
NOTE: When you register, disconnect from the Internet!
Download (3029 KB):
[-] The following 2 users Like Grunf's post:2 users Like Grunf's post
  • niki102, niki102
 verongskey
Russian Federation
User ID: 46
Threads: 39
Likes: 1,791 in 133 posts
Given Likes: 300
06-17-2009, 01:41 PM (This post was last modified: 10-12-2013, 10:50 PM by LiviuM.)
Hi there Grunf, I just want to comment on this software. I tried to used it before, I didn't like it. It says it cannot be deleted, but it can be using the unlocker. If I really need to protect my files, I'd rather use winzip and encript it, and to disguise my file to be like some other files, I am just changing the file extention of the zip to txt or to something else.
[-] The following 4 users Like verongskey's post:4 users Like verongskey's post
  • Grunf, Grunf, niki102, niki102
 niki102
User ID: 8143
Threads: 85
Likes: 2,495 in 189 posts
Given Likes: 845
10-05-2009, 05:05 PM (This post was last modified: 10-12-2013, 10:51 PM by LiviuM.)
sorry dear, I agreed..
it might not be delete directly.
U can try New version Folder Lock 6.3.0.
its working very well.
i m using with win 7. (in win7 - unlocker1.8.7 doesn't works. so no alternative.)
but I m using the built in function "delete locker".
Even then if u don't want 2 use then """sorry""".
here, links and screenshots are........
ThanXX...
 Learner
User ID: 4207
Threads: 41
Likes: 889 in 112 posts
Given Likes: 126
10-12-2009, 12:23 PM (This post was last modified: 10-12-2009, 12:40 PM by Learner.)
I tried out the New version Folder Lock 6.3.0. At first it works but then I use 2nd time it says License Expired........ either this registration on more than one computer..... Now I have problem to uninstall it by "Add or Remove program" and it is also hidden from Smarty Uninstaller 2009 Pro. Can any expert come up with a method to uninstall it? Thanks!!
For the benefit of those who want to uninstall it, I have just found after searching from other website that the "Folder Lock" can only be uninstalled by clicking the 'Uninstall Program' button, which you can only access after clicking the Options button in the 'General settings' either by opening the existing one or opening a new one both with their respective passwords. You cannot uninstall the program directly without entering the password. This is done to protect the program from being uninstalled by other users. Do not try to delete the program manually. Use only this option to remove the program from your computer.
[-] The following 4 users Like Learner's post:4 users Like Learner's post
  • niki102, niki102, Grunf, Grunf
  Folder Guard v8.4 abdulazizk 3 7,351 02-11-2013, 03:48 PM
