Civil Engineering Association Software Software Installation Problems & Bugs Archive Problem Creating Bi-Linear Curve of Pushover Analysis
 paladin
Semi Senior Member
Banned
User ID: 27662
Threads: 41
Likes: 243 in 64 posts
Given Likes: 86
09-26-2010, 06:09 AM
Dear members of Civilea
I need help
I want to create bi-linear curve of pushover analysis manually.
I use etabs.
After the pushover curve done, plz guide how to calculate Ki, Ke and 'alpha' so that I can create the bi-linear curve
Thanks & waiting your help
Paladin
[-] The following 1 user Likes paladin's post:1 user Likes paladin's post
  • BennyK
 jcoronellr
Colombia
User ID: 173
Threads: 5
Likes: 130 in 33 posts
Given Likes: 1274
09-26-2010, 03:43 PM
Greetings do not know if I understood well, but what you want to do is get the bilinear curve, well this is a process see:
1-Create capacity curve of the structure, plotting the base shear against the maximum shift in the highest level of the building, this representation is constructed in the first mode. This is valid for periods less than or equal to 1 second, for periods longer than 1 second to use the effect of higher modes.
2 - We need to determine the seismic demand, to estimate it using a technique called "equal displacement approximation, it is assumed that the inelastic spectral displacement is the same as the elastic displacement.
3 - You must convert the curve of capacity spectrum curve capacidad.y also convert the standard spectrum and spectrum capacity (ADRS).
4 - With these curves if you can build the curve bilinear capacity spectrum.
excuse my poor English, but try to he
Jaime
[-] The following 3 users Like jcoronellr's post:3 users Like jcoronellr's post
  • Grunf, paladin, BennyK
 degenkolb
Junior Member
Banned
User ID: 28099
Threads: 0
Likes: 10 in 6 posts
Given Likes: 0
09-26-2010, 06:39 PM
"equal displacement approximation". It's now rule
"well known equal displacement rule".
ADRS(Accelartion - Displacement Response Spectrum).
I think it's unnecessary
regards.
[-] The following 1 user Likes degenkolb's post:1 user Likes degenkolb's post
  • paladin
 Sumatra
User ID: 14369
Threads: 103
Likes: 1,925 in 240 posts
Given Likes: 1580
09-26-2010, 09:58 PM
Hi Paladin,
you can find the complete info in chap.8 of ATC-40 regarding this matter including capacity spectrum method (ADRS).
regards
[-] The following 2 users Like Sumatra's post:2 users Like Sumatra's post
  • Grunf, paladin
  Response Modification Factor ( R ) via Pushover analysis using SAP2000/ETABS paladin 8 12,533 09-29-2010, 02:29 PM
Last Post: paladin
  Shear reinforcement for pushover analysis in SAP2000 / ETABS paladin 14 19,704 09-26-2010, 11:21 AM
Last Post: Sumatra
  Load Pattern in pushover analysis paladin 0 3,464 09-26-2010, 06:23 AM
Last Post: paladin
