Civil Engineering Association eBooks Structural Books Steel SSMA Product Technical Catalog (Light Gauge/Cold-Formed Steel)
 goober
United States
User ID: 3294
Threads: 3
Likes: 227 in 47 posts
Given Likes: 402
Points:2,736 EP
09-06-2010, 08:21 PM (This post was last modified: 10-11-2011, 06:08 PM by Grunf.)
[Image: 60117097366005347323.jpg]
General Product Information
Introduction
The increasing environmental concerns in the world today have caused us all to examine the way we live. These issues have affected every aspect of our lives, including the materials we use in construction.
The use of cold-formed steel members as a building alternative is an intelligent choice with benefits to, not only the environment, but also to the contractor, designer and developer.
Steel is not only a recyclable product, but also a stronger product allowing for longer clear-spans in the design process. Cold-formed steel is lighter providing ease of handling. It is a straighter product giving a “true” wall with which to work. It doesn’t suffer fluctuation in price, making it easier to bid a project. Quality control is stressed in all phases of the manufacturing process so the highest possible quality is delivered to the job site.
The structural shapes manufactured are easily used for non-structural and structural assemblies, floor and ceiling joist assemblies, and panelized systems. They can be used as the main structural support system or as a supplement to heavy structural steel or concrete construction.
Manufacturers have been producing cold-formed steel framing members for many years, with each manufacturer having its own nomenclature and design values. A steel member with identical properties would be identified by different names based on which manufacturer produced it. This created some confusion at all levels of the construction process.
The SSMA's mission is to proactively represent member firms engaged in the manufacture, marketing and sale of cold-formed steel framing members, as a unified voice to the residential and light commercial
construction industry serviced by its products, which includes contractors, distributors, design professionals, code officials and standards organizations. To this end, SSMA will endeavor to supply products which meet or exceed standards established by national, state and local code bodies and by
recognized industry associations. SSMA resolves to continually initiate and adopt the development of new technology and applications for its members' products with the common goal of growing new market opportunities.
Code Approval
Products manufactured by the members recognized by ICBO Evaluation Service of the Steel Stud Manufacturers Association, SSMA, comply with the Uniform Building Code and International Building Code. See ICBO ES Evaluation Report No. 4943-P.
Material Specifications
Products manufactured by SSMA members are formed from steel with a minimum yield stress of 33 ksi or 50 ksi. All products covered in this catalog are engineered to meet the 1996 Edition of the American Iron and Steel Institute, AISI, “Specification for the Design of Cold-Formed Steel Structural Members.” The structural properties included in this brochure have been computed based on allowable stress design to conform with the same AISI document.
Disclaimer
All data, specifications and details contained in this publication are intended as a general guide for using
SSMA members products. These products should not be used in design or construction without an
independent evaluation by a qualified engineer or architect to verify the suitability of a particular product for use in a specific application. The SSMA and its members assume no liability for failure resulting from the use or misapplication of computations, detail drawings and specifications contained herein. This publication contains the latest information available at the time of printing. The SSMA and its members reserve the right to make modifications and/or change materials of any of their products without prior notice or obligation. For the latest information regarding a particular manufacturer’s products contact that manufacturer. All SSMA manufacturers may not produce all of the products contained in this catalog. Please contact manufacturer toverify product availability.
[Image: 60581664556196854185.jpg]
[-] The following 9 users Like goober's post:9 users Like goober's post
  • nuttapolk, salman22, pezhmankhan, baikur, engrasad, Nilupa, Dell_Brett, zrilek, knrsa
 goober
United States
User ID: 3294
Threads: 3
Given Likes: 402
Points:2,736 EP
10-11-2011, 09:34 PM
Re-upload w/ new links:
[-] The following 10 users Like goober's post:10 users Like goober's post
  • Grunf, Dell_Brett, malc, Jackass, tluc, zrilek, blaze, ting tsai huang, lasalleguy, lednar_ved
 andyspak2
User ID: 32354
Threads: 0
Likes: 11 in 5 posts
Given Likes: 40
Points:391 EP
10-13-2011, 08:21 AM (This post was last modified: 10-13-2011, 10:52 AM by Dell_Brett.)
There is new catalog on the SSMA website to download:
[Image: 75574646909878784397.jpg]
This is an updated section properties per new AISI 2008 and IBC2006 and later, CBC 2007 and CBC 2010, too. A must reference for design studs in USA.
Also, the screw and weld capacity is higher compare to the old code, give you some advantage to design a good connections.
Moderator Note:
Good Post! Consider use a postgenerator in next time
[-] The following 3 users Like andyspak2's post:3 users Like andyspak2's post
  • zrilek, Jackass, goober
 andersen3
User ID: 464
Threads: 54
Likes: 6,117 in 996 posts
Given Likes: 1243
Points:29,008 EP
11-16-2012, 07:41 AM
the link for the last post is outdated; link to choose what catalogue you want
  • ykhackhack, Dell_Brett, malc
  Cold-Formed Tubular Members and Connections. Structural Behaviour and Design TAFATNEB 0 2,363 04-25-2023, 10:48 AM
  Cold-Formed Steel Design Flexi 21 15,554 09-03-2022, 04:21 AM
  Recent Trends in Cold-Formed Steel Construction struceng 0 1,289 03-15-2017, 09:43 AM
Last Post: struceng
  Cold-formed Tubular Members and Connections choonguan 10 7,738 12-16-2015, 11:25 PM
Last Post: cargadory2k
  Design of Metallic Cold-Formed Thin-Walled Members babak 8 3,993 01-03-2015, 11:34 PM
Last Post: Veggeta
  SCI P301: Building Design using Cold Formed Steel Sections: Light Steel Framing in Re ir_71 2 2,660 11-13-2014, 08:42 AM
Last Post: concreteok
  SCI P247: Over-cladding of Existing Buildings using Light Steel ir_71 3 2,258 10-29-2014, 04:39 PM
Last Post: r3be1
