Numerical Analyses of Cable Roof Structures
[Image: 49767722462349560809.jpg]
TRITA-BKN. Bulletin 46, 1999
ISSN 1103-4270
ISRN KTH/BKN/EX--46--SE
Licentiate Thesis
This thesis deals with the techniques used in the numerical analysis of cable roof structures. These structures are usually very light and flexible and require analysis methods, which take their non-linear behaviour into account. An extensive literature survey, concerned with both practical and theoretical aspects of cable roofs, is presented. Some aspects included are: structural systems, roof erection procedures, different cable types and their properties, structural details, roof loads and analysis methods. As the initial shape of a cable roof depends on the internal force distribution, it cannot be described by simple geometrical models. Special iterative methods, usually not familiar to the structural engineer, have to be utilised in order to find the pretensioned configuration of the roof. The simple force density method is presented in detail and applied to a number of different types of cable roof structures. The method worked well for structures composed of only cables, but not for structures with compression members. Three analytical finite cable elements are presented. Two elements are mathematically exact and can accurately model both taut and slack cables using only one element per cable. It is shown that the analytical elements are advantageous in modelling cable behaviour. A static analysis of the Scandinavium Arena in Gothenburg has been performed. The results from this analysis were compared with results from the original design of the same object. It was found that the bending moments in the supporting structure—the concrete ring beam—were very sensitive to its shape. This explained the large discrepancy in the bending moment distribution between the analyses. Results from a simplified method, used for preliminary calculations, agreed well with those of the more accurate finite element calculations, for a studied symmetric load case.
[-] The following 26 users say Thank You to yanburak for this post:
  • Dell_Brett, vsa2010, kowheng, cristi, igor1234, Grunf, jcoronellr, jferrer, jgarciafic, ladjin, mgdario, subin91, draluka, tuntnguyen, sodapas, bl_54321, jcbv, mouhendess, blaze, toa011, oanm2000, zrilek, zainseiya, monter, Nilupa, bigone
unprotected, bookmark PDF|RAR 3.85|3.54 MB
[-] The following 13 users say Thank You to kowheng for this post:
  • toa011, Quantumm, usman, oanm2000, zrilek, zainseiya, cristi, Nilupa, draluka, bigone, sacem, KhaLed-S.E, inge911
An Introduction to cable roof structures - 2nd Edition asim99 2 2,491 09-20-2018, 02:02 PM
Last Post: febo927
Structural Plasticity: Limit, Shakedown and Dynamic Plastic Analyses of Structures rusty 7 5,426 06-28-2018, 04:13 PM
Last Post: febo927
Widespan Roof Structures hich 3 2,412 06-15-2018, 09:21 PM
Last Post: axcel
The Analysis of Cable and Catenary Structures ssobhan 3 2,817 12-20-2014, 11:18 PM
Cable Structures by Max Irvine toa011 2 4,266 11-03-2014, 09:15 AM
