Steel Design spreadsheets
Current time: 05-24-2018, 07:12 AM
Author: RedHorse
Last Post: duazo2009
Replies 3
Views 6563
"unprotected sheets/Password Removed"
if u like it, buy it,
for evaluation purposes only, not for commercial use
Steel Design.rar
contains
BasePlate.xls
BeamConnection.xls
BoltsConnection.xls
EBF-IBC.xls
EBF-UBC.xls
JoistGirder.xls
OCBF-IBC.xls
OCBF-UBC.xls
OMRF-IBC.xls
OMRF-UBC.xls
RoofDeck.xls
SCBF-IBC.xls
SCBF-UBC.xls
SMRF-IBC.xls
SMRF-UBC.xls
SteelJoists.xls
WeldConnection.xls
WF-Opening.xls
[Image: 81630613033634538611.jpg]
Engineering is the professional art of applying science to the optimum conversion of natural resources to the benefit of man
[-] The following 28 users say Thank You to RedHorse for this post:
  • kowheng, ascetic19, Dell_Brett, simanta, redtony, surajdas, cristi, jcbv, jcoronellr, r3be1, lythongnay, wagam0200, ilgar, isurya, kirananvekar, cmorpar, edgar9469, đầuto, uomo_ragno, mig21, bayoesh, priyoyo, cit_kaq, hcardenas, engiman27, tremonti, pezhmankhan, kchatza
request for spreadsheet in SI units please.
Thanks
[-] The following 2 users say Thank You to surajdas for this post:
  • bloodrn, bjliang
A word of warning. All of the Engineering International Spreadsheets that was cracked using Microsoft Office password recovery software will produce erroneous answers. The reason is because the original files downloaded from EngineeringInternational website that was used for cracking have several variables set as constant in every sheet (will not change according to user input). Therefore the results generated by these cracked spreadsheets will not be correct.
The spreadsheets that are bought will have all cells functioning as intended. The spreadsheets bought will not show Daniel T. Li at the top left corner of the spreadsheet.
Therefore all of the Engineering International spreadsheets available for download that shows Daniel T. Li in red text at upper left corner are incorrect!
[-] The following 4 users say Thank You to jacky899 for this post:
  • albani, jaks, tonmjr, Adhan
If You're just downloading and not counterchecking whether it is correct or not then it means you're not a real engineer. the real engineer itself should check whether the output from this spreadsheet is correct or not.
Duazo2009
[-] The following 9 users say Thank You to duazo2009 for this post:
  • RedHorse, tonmjr, Dell_Brett, zbizafar, oanm2000, OGBONNA, hmwere, tremonti, Adhan
Multiple Excel Spreadsheets Steel & RC -Techno Consultants Vincwilson 0 3,568 12-28-2009, 04:46 PM
Last Post: Vincwilson
