Revit extensions for Revit structure 2010
hi all
:heart::heart::heart:
(09-19-2009, 12:59 PM)hvcompxd05 Wrote: Hi mouhandiss,thank you so much for your link!
but,do you have mediafire link?
hvcompxd05
You can't download from rapidshare. I can understand. Lucky I can help you. Try download this those links & enjoy:
Second mirror link for our forums:
regard
timosi
1.Follows the rules
2.Use "Search" before posting
4.Do not spam
5.Respect the other members
[-] The following 16 users say Thank You to timosi™ for this post:
  • essam2109, essam2109, hvcompxd05, hvcompxd05, zrilek, zrilek, levanduy, levanduy, civil, civil, lonelyboy, lonelyboy, DamirDz, u4406014, relu59, jinualex
(09-30-2009, 10:22 AM)Dell Brett Wrote:
Autodesk Revit Structure 2010 Extensions Collection
[Image: 0e0gqlieul4odkhi3y08.jpg]
WinApp | Autodesk Revit Structure 2010 Extensions Collection | 542.33 Mb
The Revit Extensions for Revit Structure 2010 delivers a full range of benefits to enhance and leverage Autodesk® Revit® Structure 2010. Users of these extensions will benefit from their ease of use, enabling them to be more productive and agile while working on projects and responding to customer requests.
Enhancements in Revit Extensions for Revit Structure 2010 include:
Robot Structural Analysis
Composite Design, Load Takedown, Integration with Robot Structural Analysis, Reinforcement Design
Simulation Beams, Conceptual Form Simulation, Frames, Trusses, Slabs
AutoCAD Structural Detailing
Integration with Steel Module, Reinforcement Drawings, Integration with Formwork Drawings Module
Steel Connections (Knots)
Beam to column - end-plate, Column base
Import / Export (Import / Export)
CIS / 2 Export, CIS / 2 Import
Reinforcement (Reinforcement)
Automatic Reinforcement Generation, Parapets, Piles, Retaining Walls, Slab Corners, Wall Corners, Walls, Beams, Columns, Spread Footings, Continuous Footings, Slab Openings, Pile Caps
Modeling (Modeling)
Bridge, Excel Based Model Generation, Grids Generator
Miscellaneous (Misc)
Content Generator, Text Generator, Elements Positioning, Freeze Drawings, Compare Models
Centered on the structural analysis, modeling, reinforcement of concrete, interoperability, and documentation design, Extensions for Revit Structure 2010 Revit, an extensive range of tools, users can start to take advantage of today!
Download Links:
(10-04-2009, 07:35 AM)leithowsky Wrote: Megaupload download links
Kamran via HP :)
[-] The following 8 users say Thank You to kamran for this post:
  • subin91, subin91, zrilek, zrilek, relu59, veafrian, avscorreia, wannaspk
Autodesk Revit 2019 and Revit LT 2019 BennyP 6 3,674 09-30-2018, 06:18 PM
AUTODESK REVIT STRUCTURE V2014 WIN32/WIN64-ISO BennyP 4 3,991 04-21-2018, 10:51 PM
Last Post: joker™
Autodesk Revit 2016 (x64) BennyP 1 3,321 10-19-2017, 10:10 PM
Last Post: joker™
AUTODESK REVIT MEP V2014-ISO (x32/x64) BennyP 1 1,767 10-15-2017, 02:33 PM
Last Post: joker™
AUTODESK REVIT ARCHITECTURE V2014-ISO (x32/x64) BennyP 1 2,328 10-15-2017, 02:31 PM
Last Post: joker™
