Domain Name Expiration
I think there is a problem with the domain name registration of civilea.com. It seems that expired on 13.04.2010. Any comments or information? I can only enter to the forum with a little tricky in "hosts" file :-)
"Status: RENEWAL HOLD
Note: This Domain Name has expired. In this status the domain name is inactive. This domain name will be activated once it is renewed. The Owner of this domain name can renew this domain name from their control panel. If this domain name is not renewed by 23-May-2010, it will be permanently deleted."
[-] The following 1 user says Thank You to struceng for this post:
  • jonev
The same with me!
In my office, I receive this message too, and no access! I could only access when used outside Proxi.
In my home office, and mobille access, all is OK!
Dell Brett
[-] The following 1 user says Thank You to Dell_Brett for this post:
  • jonev
I have the same problem in my office (IE), but
in my home I use Chrome and works.
[-] The following 1 user says Thank You to yucapareja for this post:
  • jonev
All working fine now!
[-] The following 6 users say Thank You to Dell_Brett for this post:
  • Ultra Zone, Grunf, lucky_b2me, struceng, levanduy, jonev
(04-14-2010, 11:28 PM)Dell Brett Wrote: All working fine now!
Still Having problem logging. I just check this morning and the site was rerouted with the same domain expired error. But working from my office... Any ideas, how to overcome this problem?
Your link in Favorites points to
Delete it and after connecting to
replace it.
  • concreteok, zbizafar, Dell_Brett, jonev
(04-16-2010, 08:00 AM)BennyP Wrote: Your link in Favorites points to
replace it.
This is not true. It does not matter if I put or not put "www" in front of web address.
Using an trick I have managed to access the civilea from the same computer which one couldn't get access to civilea.
I don't now how long will work this thick, but civilea team should solve this restriction.
[-] The following 1 user says Thank You to igor1234 for this post:
  • jonev
This is was i did and works. Telling is not true is based on what ?
If you have two records in the dns server data base one with and one without www you are right but if is only one without www the stupid server can translate the IP address only for it and don't know you decided i'm wrong but don't detail your trick for all.
You tell us we should do something, and your job is to criticize only ?
  • jonev
all problem fixed...
domain name & host renew again ...
[-] The following 17 users say Thank You to Administrator for this post:
  • Dell_Brett, igor1234, levanduy, ska51, rendel_©, Josep Soroz, concreteok, Ultra Zone, zbizafar, iceman84, Grunf, aslam, user, cve_jule, jaks, dinu69in, jonev
A problem connected with the manyiatech.com - entering a thread, a popup change the page and don't permit to see the thread. A temporary solution for users seeing this post:
In internet expolorer when the maniyatech.com page is visible go to:
Tools
Internet options
Security
Restricted sites
Add
Close
OK
  • rohailiyaz, Dell_Brett, jonev
