Civil Engineering Association eBooks Journals, Papers and Presentations Design of Anchor Reinforcement in Concrete Pedestals
 dinu69in
User ID: 16081
Threads: 78
Likes: 1,507 in 138 posts
Given Likes: 1634
Points:8,089 EP
04-08-2010, 05:05 PM
Even though the Appendix D of the ACI 318-05 permits the use of supplementary reinforcement to restrain concrete breakout, it does not provide specific guidelines in designing such reinforcement. This paper presents a method for designing anchor reinforcement in concrete pedestals, where un-reinforced concrete is insufficient to resist anchor forces. Anchor reinforcement consists of longitudinal rebar and ties to carry anchor tension forces and shear forces, respectively. The Strut-and-Tie Model is proposed to analyze shear force transfer from anchors to pedestal and to design the required amount of shear reinforcement. A proposed design procedure is illustrated in an example problem.
[Image: 85465637158662415924.jpg]
[-] The following 33 users Like dinu69in's post:33 users Like dinu69in's post
  • Ultra Zone, texv, pssst, Grunf, Dell_Brett, avscorreia, jjmtz, henrycv, robertsas, jacs127, kowheng, ziggywas1, brichard, engr1900, joradu, nhim4mat2006, levanduy, batata666, cristi, vantoancons, subin91, yucapareja, hsccindia, leithowsky, pram, sodapas, fer962933, dexter238, davegabj, Umer.Aleem, agelos100, Hengki, malc
 joradu
User ID: 14569
Threads: 15
Likes: 166 in 14 posts
Given Likes: 106
Points:1,958 EP
04-09-2010, 08:52 AM
do you have sample problems with L or J type anchor bolts? What about using CM 66 instead of using ACI 318 Appendix D?
  Design of Anchor Reinforcement for Seismic Shear Loads asim99 0 3,519 03-17-2013, 12:08 AM
Last Post: asim99
  Guide for the use of stainless steel reinforcement in concrete structures ir_71 0 4,015 12-08-2010, 02:16 PM
  RECENT ADVANCES IN GROUND ANCHOR AND GROUND REINFORCEMENT TECHNOLOGY giguni 0 4,659 09-27-2010, 02:38 PM
Last Post: giguni
  design-of-anchor-reinforcement.pdf RedHorse 0 5,172 08-16-2010, 08:32 AM
Last Post: RedHorse
  Effects of Transverse Reinforcement and Bonded length on the Side-Blowout Capacity of Headed Reinforcement yucapareja 1 5,341 04-29-2010, 03:14 AM
Last Post: zbizafar
