Civil Engineering Association eBooks Water & Hydraulic Engineering Visual Hydrology
Visual Hydrology
 Smithy
User ID: 2485
Threads: 15
Likes: 367 in 39 posts
Given Likes: 30
02-11-2010, 02:46 AM
Visual Hydrology
[Image: 22045771355341184340.jpg]
One approach to the introduction of computational material to the classroom is to supplement a textbook with modern computer codes. Unfortunately most codes are expensive, designed for commercial use, without source code and may require special software. Visual Hydrology provides a cheaper and simpler alternative, supplying computational exercises that can be fully assimilated by students, and allowing them to activate, understand and reproduce modern computer code.
Visual Hydrology aims to:
•explain the structure of modern object-oriented computer code
•provide the source code for worked examples
•numerically check the worked examples used in text
•show how worked examples can be used with alternative data
•describe and reference the underlying theory
•provide additional exercises with each worked example
•use Microsoft Excel software alone
Requiring only a basic knowledge of Microsoft Excel, this Primer teaches the use of modern and readily-available computer code for engineering computation. Visual Hydrology demonstrates codes for common and practical examples used in hydrological engineering, and will be a valuable resource to students, research workers and consulting engineers in the water-related sector.
Source Code Files to accompany the book, can be downloaded from:
Enjoy
Adam
[-] The following 10 users Like Smithy's post:10 users Like Smithy's post
  • kowheng, rohailiyaz, sasan51, freestar, cybermad, Dell_Brett, ska51, Haseeb Jamal, civil35, utan
 abudabeeja
User ID: 1245
Threads: 496
Likes: 10,106 in 672 posts
Given Likes: 1271
02-17-2010, 10:51 AM
New link
[-] The following 5 users Like abudabeeja's post:5 users Like abudabeeja's post
  • Haseeb Jamal, Grunf, civil35, ska51, utan
 ska51
User ID: 11535
Threads: 427
Likes: 9,406 in 1,251 posts
Given Likes: 4017
02-03-2012, 06:42 PM (This post was last modified: 02-03-2012, 08:23 PM by 3fan.)
"Downstream is Weaker"
[-] The following 7 users Like ska51's post:7 users Like ska51's post
  • Dell_Brett, 3fan, pedzaquino, utan, malc, blaze, spat
  Handbook of Engineering Hydrology: Environmental Hydrology and Water Management (Volu febo927 0 1,459 09-28-2018, 05:01 PM
Last Post: febo927
  Handbook of Engineering Hydrology: Environmental Hydrology and Water Management cace-01 3 2,642 03-07-2016, 10:43 PM
