Civil Engineering Association eBooks Environmental Engineering Waste Materials Used in Concrete Manufacturing
02-03-2010, 09:02 AM (This post was last modified: 11-02-2010, 06:21 AM by Grunf.)
Waste Materials Used in Concrete Manufacturing (Building Materials Science Series)
[Image: 51QWXJEDEML.jpg]
By Satish Chandra
* Publisher: William Andrew
* Number Of Pages: 672
* Publication Date: 1997-01-14
* ISBN-10 / ASIN: 0815513933
* ISBN-13 / EAN: 9780815513933
Product Description:
The environmental aspects involved in the production and use of cement, concrete and other building materials are of growing importance. CO2 emissions are 0.8-1.3 ton/ton of cement production in dry process. SO2 emission is also very high, but is dependent upon the type of fuel used. Energy consumption is also very high at 100-150 KWT/ton of cement produced. It is costly to erect new cement plants. Substitution of waste materials will conserve dwindling resources, and will avoid the environmental and ecological damages caused by quarrying and exploitation of the raw materials for making cement. To some extent, it will help to solve the problem otherwise encountered in disposing of the wastes. Partial replacement of clinker or portland cement by slag, fly ash, silica fume and natural rock minerals illustrates these aspects. Partial replacement by natural materials that require little or no processing, such as pozzolans, calcined clays, etc., saves energy and decreases emission of gases. The output of waste materials suitable as cement replacement (slags, fly ashes, silica fumes, rice husk ash, etc.) is more than double that of cement production.
These waste materials can partly be used, or processed, to produce materials suitable as aggregates or fillers in concrete. These can also be used as clinker raw materials, or processed into cementing systems. New grinding and mixing technology will make the use of these secondary materials simpler. Developments in chemical admixtures: superplasticizers, air entraining agents, etc., help in controlling production techniques and, in achieving the desired properties in concrete.
Use of waste products is not only a partial solution to environmental and ecological problems; it significantly improves the microstructure, and consequently the durability properties of concrete, which are difficult to achieve by the use of pure portland cement. The aim is not only to make the cements and concrete less expensive, but to provide a blend of tailored properties of waste materials and portland cements suitable for specified purpose. This requires a better understanding of chemistry, and materials science.
There is an increasing demand for better understanding of material properties, as well as better control of the microstructure developing in the construction material, to increase durability. The combination of different binders and modifiers to produce cheaper and more durable building materials will solve to some extent the ecological and environmental problems.
Rar'd PDF ~ 25.6 MB's Bookmarked
If you like this book, CivilEAs' staff strongly suggest you to buy it! Support the authors!
[-] The following 11 users Like Grunf's post:11 users Like Grunf's post
  • abudabeeja, kowheng, Ultra Zone, chenamoy, zrilek, Dell_Brett, Haseeb Jamal, wanazri, toa011, oanm2000, ska51
 mowafi3m
Egypt
User ID: 1236
Threads: 384
Likes: 9,309 in 673 posts
Given Likes: 1663
11-02-2010, 05:23 AM
Mirror Link
[-] The following 5 users Like mowafi3m's post:5 users Like mowafi3m's post
  • Grunf, Dell_Brett, toa011, oanm2000, triance
 kvtasp
User ID: 7690
Threads: 69
Likes: 2,028 in 379 posts
Given Likes: 791
01-30-2012, 04:55 PM
[-] The following 3 users Like kvtasp's post:3 users Like kvtasp's post
  • Dell_Brett, Grunf, cristi
  Waste Materials and By-Products in Concrete Grunf 3 3,275 03-26-2014, 07:25 AM
Last Post: Mohammad6299
  Waste Management: Research Advances to Convert Waste to Wealth shadabg 1 1,935 01-05-2013, 05:40 PM
Last Post: ska51
  Environmental Aspects of Construction with Waste Materials Grunf 1 2,177 07-20-2012, 01:38 PM
  Use of Waste Materials in Highway Construction Grunf 3 2,983 06-28-2012, 12:54 AM
  Waste Materials in Construction abudabeeja 1 2,228 01-15-2012, 06:30 PM
Last Post: Administrator
