Civil Engineering Association eBooks Structural Books Steel SCI P326: Steelwork Design Guide to BS 5950-1 2000 6Ed
 username123
User ID: 7763
Threads: 2
Likes: 269 in 13 posts
Given Likes: 2
11-20-2009, 03:48 PM (This post was last modified: 12-13-2011, 09:27 PM by usman.)
Steelwork design guide to BS 5950-1:2000
[Image: 01856773617230674051_thumb.jpg]
Steelwork design guide to BS 5950-1:2000. Volume 1 - section properties, member capacities (Blue book). 6th edition, 2002
Provides a comprehensive range of member property and capacity tables in accordance with BS 5950-1:2000. Explanatory notes address dimensions of sections, section properties, and effective section properties.
[-] The following 39 users Like username123's post:39 users Like username123's post
  • vvvv, kowheng, chenamoy, robertsas, babak, rohailiyaz, baikur, zrilek, golpesar, min maung, Nilupa, wahta, hawking, duazo2009, dovsky, thebeatles, shmpabe, blaze, hmwere, oanm2000, 3fan, seriousboy, DamaD, fadli, tamboon, monter, cowboy, simanta, kmmh76, Svetoslav, jcbv, slowet, ikoleci, knrsa, andersen3, lednar_ved, mowafi3m, bigone, warbeast
04-13-2011, 05:21 AM
SCI P326: Steelwork design guide to BS 5950-1:2000 Volume 2: Worked examples
Author: M D Heywood, J B Lim | Size: 2.5 MB | Format: PDF | Publisher: SCI | Year: 2003 | pages: 186 | ISBN: 1859421423
[Image: 20738982225379818009.jpg]
This publication is intended to provide practising engineers and students with a guide to meeting the requirements of BS 5950-1: 2000 Structural use of steelwork in building[1] and contains worked examples that have been prepared to give a detailed indication of the process of designing members to this Code. The worked examples deal with all the main checks required by the Code and point out those which will normally be critical in design. The emphasis has been to illustrate the points in the Code rather than attempt to match practical cases exactly.
In addition to the design of simple elements, a number of frames and combinations of members have been included. Generally, the solutions illustrated are aimed at the most economical use of steel but it is emphasized that other solutions may be equally acceptable. No consideration has been given to factors governing erection and fabrication; the considerations of these factors and the standardization of sizes may well lead to solutions with better overall economy.
Unless otherwise stated, the clause and table numbers given in the right-hand margin of the examples refer to BS 5950-1:2000[1]. Where a reference is made to a page in “Vol 1” this refers to Steelwork design to BS 5950-1:2000 – Volume 1 Section properties member capacities[2], commonly known as the “Blue Book”.
[-] The following 28 users Like ir_71's post:28 users Like ir_71's post
  • kowheng, blaze, sumiscute, vardan, lirizen, hmwere, vvvv, oanm2000, malc, almadar12, seriousboy, kmmh76, robertsas, cordoba123, zrilek, Nilupa, cristi, fadli, tamboon, monter, baikur, cowboy, Adam Smith, kvtasp, lednar_ved, mowafi3m, bigone, warbeast
 jcbv
User ID: 19792
Threads: 31
Likes: 962 in 84 posts
Given Likes: 7825
06-10-2012, 07:58 AM (This post was last modified: 06-10-2012, 08:09 AM by BennyP.)
[-] The following 8 users Like jcbv's post:8 users Like jcbv's post
  • zrilek, NBZ1400, gulilero, Jackass, knrsa, royal_eagle, mowafi3m, bigone
 vinnunsam
User ID: 3932
Threads: 36
Likes: 1,281 in 116 posts
Given Likes: 457
02-18-2014, 10:00 AM
Mirror Link
[Image: 03153576782836039943.jpg]
[-] The following 12 users Like vinnunsam's post:12 users Like vinnunsam's post
  • Dell_Brett, agelos100, jcbv, Andrew seah, malc, PinkPant, chenamoy, Hengki, zrilek, harsono, yanburak, bridgeengineer
  Structural steelwork: analysis and design abudabeeja 9 7,290 12-04-2015, 08:09 PM
Last Post: cargadory2k
  Structural Steelwork: Design to Limit State Theory: T.J. MacGinley, T.C. Ang babak 9 7,657 11-10-2015, 02:37 AM
Last Post: ibg0203
  Plastic Design to BS 5950 robertsas 2 3,039 12-17-2014, 03:38 AM
  Limit States Design of Structural Steelwork - by David Nethercot abudabeeja 7 7,415 07-13-2014, 03:39 PM
Last Post: i_kabir
  SCI P080: Fire resistant design of steel structures - A handbook to BS 5950: Part 8 ir_71 2 2,646 05-14-2014, 05:33 AM
  SHS Design to BS 5950 Part 1 ir_71 2 2,684 03-31-2014, 08:52 PM
Last Post: yanburak
  Steelwork Design Guide to BS 5950-1: 2000 jmpkumara 2 3,526 02-18-2014, 09:43 AM
Last Post: vinnunsam
