Civil Engineering Association eBooks Structural Books Other Materials (Wood, Brick, etc.) Hybrid fiber reinforced concrete-encased steel truss beams for earthquake-resistant f
 moon79
User ID: 4744
Threads: 2
Likes: 5 in 1 posts
Given Likes: 9
11-15-2009, 07:51 AM
Hybrid fiber reinforced concrete-encased steel truss beams for earthquake-resistant framed structures
The research work presented herein focuses on the behavior of a new type of precast framed structure that consists of steel-concrete hybrid beams and reinforced concrete (RC) columns for use in regions of high seismicity. The hybrid beams consist of a steel truss encased in steel Fiber Reinforced Concrete (FRC). The FRC-encased truss provides excellent strength, stiffness and energy dissipation capacity while the randomly oriented steel fibers enhance material ductility and beam shear strength. A new connection scheme was developed for adequate moment and shear transfer between the hybrid beam and RC column during large displacement reversals. Moment transfer was achieved through a combination of external steel rods and steel members connected to the truss chords, while adequate shear transfer was ensured through a bolted connection between the precast column and the embedded steel truss.
In the experimental phase of this research, four beam-column connection subassemblies were tested under large displacement reversals in order to evaluate the seismic performance of the proposed hybrid beam-RC column connection. Test results showed that the proposed connection scheme was effective in transferring moment and shear during large displacement reversals. In addition, beam inelastic rotations of up to 4.4% were measured in the hybrid beams, with good stiffness retention and energy dissipation capacity.
In the analytical phase of the study, models for predicting the envelope moment rotation response of the FRC-encased steel truss beams and their hysteretic behavior were first developed. Then, a prototype precast frame with FRC-encased steel truss beams and RC columns was designed for target roof drifts of 2.0% and 3.0% under ground motions with 10% and 2% probability of exceedance in 50 years, respectively, through the use of an energy-based method. The seismic behavior of the precast frame was evaluated through push-over analysis, as well as inelastic dynamic analyses under ground motions of various intensities. Analysis results showed that the proposed precast frame system is capable of satisfying the target performance criteria provided that the external connections are designed such that joint elastic rotations are limited to 0.5%.
  Mechanics of Fiber and Textile Reinforced Cement Composites i_kabir 2 2,221 10-03-2015, 06:26 PM
Last Post: ssobhan
  Fiber-Reinforced Composites - Materials, Manufacturing, and Design, Third Edition ir_71 7 5,099 04-17-2014, 11:37 AM
Last Post: Mohammad6299
  Fiber Reinforced Polymers: The Technology Applied for Concrete Repair ir_71 0 1,688 01-23-2013, 07:41 PM
  Behaviour of partially encased composite column made up of high performance concrete miquan 0 1,453 09-17-2011, 08:54 AM
Last Post: miquan
  Analytical and Experimental Study of Fiber-Reinforced Strip Isolators garcia 1 1,932 03-25-2011, 10:54 AM
Last Post: Grunf
  AAMA 305-06 Fiber reinforced thermoset profiles Solution 0 1,800 07-07-2009, 07:51 PM
Last Post: Solution
