Civil Engineering Association eBooks Structural Books Concrete Reinforced Concrete Structures
 vinnunsam
User ID: 3932
Threads: 36
Likes: 1,281 in 116 posts
Given Likes: 457
11-14-2009, 09:27 PM (This post was last modified: 11-14-2009, 09:31 PM by Dell_Brett.)
Concrete Structures
[Image: 08628035317545382432.jpg]
Reinforced concrete, as a composite material, has occupied a special place in the modern construction of different types of structures due to its several advantages. Italian architect Ponti once remarked that concrete liberated us from the rectangle. Due to its flexibility in form and superiority in performance, it has replaced, to a large extent, the earlier materials like stone, timber and steel. Further, architect's scope and imaginations have widened to a great extent due to its mouldability and monolithicity. Thus, it has helped the architects and engineers to build several attractive shell forms and other curved structures. However, its role in several straight line structural forms like multistoried frames, bridges, foundations etc. is enormous.
The design of these modern reinforced concrete structures may appear to be highly complex. However, most of these structures are the assembly of several basic structural elements such as beams, columns, slabs, walls and foundations (Anim. 1.1.1). Accordingly, the designer has to learn the design of these basic reinforced concrete elements. The joints and connections are then carefully developed.
Design of reinforced concrete structures started in the beginning of last century following purely empirical approach. Thereafter came the so called rigorous elastic theory where the levels of stresses in concrete and steel are limited so that stress-deformations are taken to be linear. However, the limit state method, though semi-empirical approach, has been found to be the best for the design of reinforced concrete structures
Download Links:
[-] The following 13 users Like vinnunsam's post:13 users Like vinnunsam's post
  • kowheng, yakwetu, oanm2000, legarleon, jonamcivil, levanduy, saxasa, freestar, zrilek, u4406014, wahta, Nilupa, Clouseau
 vinnunsam
User ID: 3932
Threads: 36
Given Likes: 457
11-15-2009, 08:56 AM (This post was last modified: 11-15-2009, 09:06 AM by concreteok.)
Sorry for the inconvenience friends.
I have bound all the PDF files into one file now.
Here is the new link for the "Design Of reinforced Concrete Structured"
Yours
Vinu
[-] The following 32 users Like vinnunsam's post:32 users Like vinnunsam's post
  • Dell_Brett, robertsas, oanm2000, legarleon, jonamcivil, levanduy, telefere, Grunf, Alexander, henrycv, king12, cristi, simanta, zrilek, goober, andi jackson, civilphongvan, sangen, boycv, rvkumar361, rendel_©, sodapas, michaelsoe, denim, wahta, rezart, portal61, Mr_popo, we_mbm, Nilupa, kirananvekar, Clouseau
  CEB: Seismic Design of reinforced concrete structures for controlled inelastic respon lamkin 8 5,911 12-26-2022, 10:50 AM
  Reinforced Concrete Structures: Analysis and Design ska51 6 5,967 11-07-2022, 11:56 AM
Last Post: haniakkari
  Durability of Reinforced Concrete Structures Dobblo 0 1,503 04-13-2020, 04:38 PM
Last Post: Dobblo
  Design Guide for Economical Reinforced Concrete Structures 2016 A guide to assist des sabooryan 1 2,065 01-11-2020, 08:53 AM
  Fiber-Reinforced Polymer: Reinforcement for Concrete Structures abudabeeja 1 2,773 05-21-2019, 06:35 AM
  Blast Resistant Design Guide for Reinforced Concrete Structures Nita1391 2 2,559 05-01-2019, 02:34 AM
  Ciria - Guide to the Reinforced Construction of Reinforced Concrete in the Arabian Pe Jackass 1 3,743 02-23-2019, 11:34 AM
Last Post: Icivilea
