Civil Engineering Association eBooks Codes, Manual & Handbook ACI ACI RAP-14: Concrete Removal Using Hydrodemolition
Likes: 8,200 in 1,338 posts
08-28-2024, 07:02 AM
Author(s)/Editor(s): ACI Committee E706 | Size: 1.57 MB| Format: PDF| Quality: Original preprint
[Image: 96230052681269769101.png]
FIELD GUIDE TO CONCRETE REPAIR APPLICATION PROCEDURES
This method may be used in a broad range of applications requiring concrete removal and surface preparation prior to installation of a repair material. Removal of deteriorated concrete may include concrete that is spalled, cracked, delaminated, chloride contaminated, carbonated, or damaged by fire or cycles of freezing and thawing. It may also include removal of sound concrete to provide proper clearance under the reinforcing steel or to provide a minimum thickness of repair material. The process may be used when vibration of the structure from the use of impact removal methods may lead to further damage or where vibration and sound is easily transmitted and will interfere with the simultaneous occupancy and use of the structure.
  • babakfeyzi, Dell_Brett
  [CivilEA Exclusive] ACI 225.1: Removal of Optional Alkali Limit in Standard Specifications for Portland C poolmand 0 1,438 10-25-2023, 08:09 AM
  ACI 364.8: Hydrodemolition for Concrete Removal in Unbonded Post-Tensioned Systems poolmand 0 1,242 05-02-2023, 11:55 AM
  ACI 364.6: Concrete Removal in Repairs Involving Corroded Reinforcing Steel poolmand 0 1,335 05-02-2023, 11:43 AM
