Civil Engineering Association eBooks Codes, Manual & Handbook ISO ISO 4773: Non-destructive testing Ultrasonic guided-wave testing using the phased-arr
02-03-2024, 10:42 AM
ISO 4773:2023 Non-destructive testing Ultrasonic guided-wave testing using the phased-array technique
| Size: 4.87 MB| Format: PDF| Quality: Scanner| Year: 2023| pages: 18
[Image: 81622919281537543721.jpg]
This document specifies a concept of application of phased-array guided-wave testing for various types of inaccessible structures, including buried pipelines.
Materials considered are carbon steel and stainless steel. This document does not include principles and criteria for underground facilities and the phased-array ultrasonic guided-wave testing scheme.
Furthermore, this document consists of an optimized process to draw reliable test results on inaccessible pipe cases. This document provides guidance on the use of phased-array guided-wave testing for various types of inaccessible structures, including buried pipelines made of carbon steel and stainless steel. The methodology outlined in this document includes an optimized process for achieving reliable test results on inaccessible pipe cases, with adjustments made to the beam pattern of the GW's focus location based on the defect type, location, and frequency. The process also takes into consideration the distribution diagram of the guided waves and the characteristics of the selected mode, with optimal focusing and steering achieved by adjusting the excitation time delay for each transducer based on the number of circumferential arrangement intervals of a given array probe.
  • babakfeyzi, PinkPant, kowheng
  ISO 22477 Geotechnical investigation and testing poolmand 0 2,788 03-03-2024, 06:58 AM
  ISO 17892-9: Geotechnical investigation and testing — Laboratory testing of soil Cons poolmand 0 2,720 07-22-2023, 05:56 AM
  EN 12350-1:Testing fresh concrete - Part 1: Sampling concreteok 0 2,542 01-13-2021, 06:56 AM
Last Post: concreteok
  ISO 1920-2:2005 Testing of concrete — Part 2: Properties of fresh concrete ir_71 2 2,912 12-04-2017, 05:01 AM
  CEN/TS ISO 17892, parts 1-4 Geotechnical investigation and testing - Laboratory testi ir_71 5 4,505 01-08-2015, 05:33 PM
  ISO 12106:2003 Metallic materials — Fatigue testing ir_71 2 2,791 01-08-2015, 04:11 PM
  BS ISO 10332:2010 Non-destructive testing of steel tubes - Automated ultrasonic testi ir_71 2 2,727 01-08-2015, 04:06 PM
