Civil Engineering Association eBooks Codes, Manual & Handbook ACI [CivilEA Exclusive] ACI 364.7: Evaluation and Minimization of Bruising in Concrete Repair
11-05-2023, 06:59 AM (This post was last modified: 11-05-2023, 07:08 AM by Administrator. Edit Reason: N/A )
ACI PRC-364.7-21: Evaluation and Minimization of Bruising in Concrete Repair
Author(s)/Editor(s): ACI Committee 364 | Size: 2.95 MB| Format: PDF| Quality: Scanner| Year: 2021| pages: 5
[Image: 77369695069520359987.jpg]
What is concrete “bruising,” how is it evaluated, and how can it be minimized?
Bruising refers to damage in a surface layer of remaining substrate concrete that is weakened by fine interconnected
cracks caused by the use of high-impact, mechanical methods for concrete removal and surface preparation. The bruised (or fractured) layer left by such surface preparation methods typically extends to a depth of 1/8 to 3/8 in. (3 to 10 mm) or more below the remaining substrate surface and, if not removed, generally results in lower repair bond strengths. Bruising, which can be detected through pulloff testing and petrographic examination, can be effectively minimized by selecting the most appropriate method and equipment for the given application.
bond strength; breaker; bruising; concrete removal; cracking; hammer; microcracking; pulloff test; repair; surface
preparation.
  • PinkPant, babakfeyzi, kowheng
  [CivilEA Exclusive] ACI 563: Repair of Concrete in Buildings—Specification poolmand 0 2,748 04-19-2025, 12:51 PM
  [CivilEA Exclusive] ACI SP-364: Serviceability and Performance Evaluation of Concrete Bridges and Structu poolmand 0 2,436 04-19-2025, 12:42 PM
  ACI RAP-12: Concrete Repair by Shotcrete Application poolmand 0 1,347 08-28-2024, 06:57 AM
  ACI RAP-7: Spall Repair of Horizontal Concrete Surfaces poolmand 0 1,314 08-28-2024, 06:47 AM
  ACI RAP-3: Concrete Repair by Low-Velocity Spraying poolmand 0 1,483 08-28-2024, 06:35 AM
  ACI E702.8: Designing Concrete Structures: Evaluation of Concrete Cores Test Results poolmand 0 1,287 08-28-2024, 06:12 AM
  ACI 546.3: Materials Selection for Concrete Repair—Guide poolmand 0 1,888 03-03-2024, 10:51 AM
