Civil Engineering Association eBooks Codes, Manual & Handbook AWS AWS D14.9/D14.9M: Specification for the Welding of Hydraulic Cylinders
Likes: 8,200 in 1,338 posts
09-09-2023, 12:58 PM
AWS D14.9/D14.9M-2013: Specification for the Welding of Hydraulic Cylinders
| Size: 18.2 MB| Format: PDF| Quality: Scanner| Year: 1st Edition, 2013| pages: 64
[Image: 76044804931251076701.jpg]
This specification provides requirements for the design and manufacture of welded joints of hydraulic cylinders. When specified in the purchasing documents, compliance with all the requirements shall be required. This specification does not apply to the manufacture of welded tubing used for hydraulic cylinders which is covered under ASTM and other recognized specifications. This specification does not specify load determination, design assumptions, safety factors, or calculation methods for non-weld related areas of the hydraulic cylinder.
The Manufacturer's adherence to this specification shall include responsibility for the following:
(1) welding, as defined in 1.1.1, in accordance with this specification;
(2) producing welds as designated on drawings by appropriate symbols and notes, with sufficient detail to show joint preparation compatible with applied processes;
(3) providing written welding procedure specifications (WPSs);
(4) recording and maintaining results of all welding procedure and welder performance qualification tests;
(5) controlling use of designated base metals and welding consumables;
(6) inspecting the welds to the requirements of this specification;
(7) having a welding quality program in place. The requirements of AWS B5.17, Specification for the Qualification of Welding Fabricators may be used as a guide in establishing this welding quality program. Accreditation of quality systems of welding fabricators may be obtained through the AWS Certified Welding Fabricator (CWF) or equivalent programs.
  • babakfeyzi, rami1976, PinkPant, kowheng
  [CivilEA Exclusive] A5.22 / A5.22M: SPECIFICATION FOR STAINLESS STEEL FLUX CORED AND METAL CORED WELDING poolmand 0 2,528 02-03-2025, 06:02 AM
  AWS D17.1/D17.1M: SPECIFICATION FOR FUSION WELDING FOR AEROSPACE APPLICATIONS poolmand 1 3,151 09-24-2024, 07:29 AM
  [CivilEA Exclusive] AWS D14.0/D14.0M: MACHINERY AND EQUIPMENT WELDING SPECIFICATION poolmand 0 2,771 09-24-2024, 07:18 AM
  AWS A5.14/A5.14M: Specification for Nickel and Nickel- Alloy Bare Welding Electrodes poolmand 1 3,049 01-27-2024, 11:18 AM
  AWS J1.3/J1.3M: SPECIFICATION FOR MATERIALS USED IN RESISTANCE WELDING ELECTRODES poolmand 0 2,742 01-22-2024, 12:10 PM
  AWS J1.1M/J1.1: SPECIFICATION FOR RESISTANCE WELDING CONTROLS poolmand 0 2,796 01-22-2024, 12:05 PM
  AWS G1.2M/G1.2: SPECIFICATION FOR STANDARDIZED ULTRASONIC WELDING TEST SPECIMEN FOR T poolmand 0 1,785 01-22-2024, 11:29 AM
