Civil Engineering Association eBooks Books, Codes, Theses, Journals & Papers Request Theses, Journals and Papers Request [REQUEST] Local Compression Property of Rammed Earth Wall with Bamboo Cane Based on ANSYS
[Request] Local Compression Property of Rammed Earth Wall with Bamboo Cane Based on ANSYS
02-02-2022, 09:48 AM
Abstract: Local compression damage is a common form of damage in the rammed earth wall bearing buildings.Local compression property of rammed earth wall with bamboo cane under roof load was analyzed using the finite element software ANSYS. Through comparison with rammed earth wall without bamboo cane,the role of bamboo cane in rammed earth wall was analyzed. The role of the method adding wooden blocks in improving local compression property was analyzed. The results indicate that there is obvious stress concentration at the contact area of wall and purlins. The bamboo cane can reduce the displacement of rammed earth wall,and increase the integrity of wall,but there's no use for improving local compression property. The method of adding wooden blocks can improve local compression property effectively.
[-] The following 1 user Likes Grunf's post:1 user Likes Grunf's post
  • freequo
 lisine
Vanuatu
User ID: 17927
Threads: 272
Likes: 11,709 in 1,305 posts
Given Likes: 4621
02-02-2022, 12:53 PM
Maybe
or link for paper
[-] The following 3 users Like lisine's post:3 users Like lisine's post
  • freequo, zrilek, PinkPant
