Civil Engineering Association eBooks Codes, Manual & Handbook AASHTO AASHTO Provisional Standards
01-25-2022, 01:04 PM (This post was last modified: 01-25-2022, 01:05 PM by poolmand.)
AASHTO Provisional Standards, 2009 Edition
| Size: 16.49 MB| Format: PDF| Quality: Original preprint| Publisher: AASHTO| Year: 2009| pages: 555 | ISBN: 1615831207 , 9781615831203
Description:
This 13th Edition of the AASHTO Provisional Standards contains a complete set of 41 provisional materials specifications and test methods. All Provisional Standards are approved for publication by the AASHTO Highway Subcommittee on Materials. Provisional Standards are standards which have been adopted by the Highway Subcommittee on Materials on a temporary basis for a maximum of eight years. A chronology of the year-to-year status of the Provisional Standards during the past eight years is included. At any time during the eight-year period, the Subcommittee can ballot to convert a Provisional Standard into a Full Standard. The Subcommittee, so far, has converted 58 Provisional Standards into Full Standards. These Standards are now regularly published in the AASHTO Standard Specifications for Transportation Materials and Methods of Sampling and Testing.
Content:
Front Matter
• Table of Contents
  • Aggregates MP 16-07 - Reclaimed Concrete Aggregate for Use as Coarse Aggregate in Hydraulic Cement Concrete
  • TP 77-09 - Specific Gravity and Absorption of Aggregate by Volumetric Immersion Method
  • Bituminous Materials MP 15-09 - Use of Reclaimed Asphalt Shingles as an Additive in Hot Mix Asphalt (HMA)
  • PP 53-09 - Design Considerations When Using Reclaimed Asphalt Shingles (RAS) in New Hot Mix Asphalt (HMA)
  • PP 60-09 - Preparation of Cylindrical Performance Test Specimens Using the Superpave Gyratory Compactor (SGC)
  • PP 61-09 - Developing Dynamic Modulus Master Curves for Hot Mix Asphalt (HMA) Using the Asphalt Mixture Performance Tester (AMPT)
  • PP 62-09 - Developing Dynamic Modulus Master Curves for Hot Mix Asphalt (HMA)
  • TP 62-07 - Determining Dynamic Modulus of Hot Mix Asphalt (HMA)
  • TP 63-09 - Determining Rutting Susceptibility of Hot Mix Asphalt (HMA) Using the Asphalt Pavement Analyzer (APA)
  • TP 68-04 - Density of In-Place Hot Mix Asphalt (HMA) Pavement by Electronic Surface Contact Devices
  • TP 70-09 - Multiple Stress Creep Recovery (MSCR) Test of Asphalt Binder Using a Dynamic Shear Rheometer (DSR)
  • TP 71-09 - Evaluation of Superpave Gyratory Compactor (SGC) Internal Angle of Gyration Using Simulated Loading
  • TP 72-08 - Quantitative Determination of the Percentage of Lime in Hot Mix Asphalt (HMA)
  • TP 78-09 - Detecting the Presence of Phosphorous in Asphalt Binder
  • TP 79-09 - Determining the Dynamic Modulus and Flow Number for Hot Mix Asphalt (HMA) Using the Asphalt Mixture Performance Tester (AMPT)
  • Box Culvert, Culvert Pipe, and Drain Tile PP 63-09 - Pipe Joint Selection for Highway Culvert and Storm Drains
  • Concrete PP 54-06 - Match Curing of Concrete Test Specimens
  • PP 58-08 - Static Segregation of Hardened Self-Consolidating Concrete (SCC) Cylinders
  • TP 59-00 - Determining Air Content of Hardened Portland Cement Concrete by High-Pressure Air Meter
  • TP 64-03 - Predicting Chloride Penetration of Hydraulic Cement Concrete by the Rapid Migration Procedure
  • TP 73-09 - Slump Flow of Self-Consolidating Concrete (SCC)
  • TP 74-09 - Passing Ability of Self-Consolidating Concrete (SCC) by J-Ring
  • TP 75-08 - Air-Void Characteristics of Freshly Mixed Concrete by Buoyancy Change
  • TP 80-09 - Visual Stability Index (VSI) of Self-Consolidating Concrete (SCC)
  • Metallic Materials and Coatings for Bridges MP 12-04 - Detectable Warning Surfaces
  • MP 13M/MP 13-04 - Stainless Clad Deformed and Plain Round Steel Bars for Concrete Reinforcement
  • MP 18M/MP 18-09 - Uncoated, Corrosion-Resistant, Deformed and Plain Alloy, Billet-Steel Bars for Concrete Reinforcement and Dowels
  • PP 45-07 - Qualification of Deformed and Plain Steel Bar Producing Mills
  • PP 55-06 - Overcoating Field Test Program for Evaluating Protective Coatings on Existing Bridges or Salvaged Beams
  • Pavement Structures MP 11-08 - Inertial Profiler
  • MP 14-08 - Smoothness of Pavement in Weigh-in-Motion (WIM) Systems
  • MP 17-08 - Pavement Ride Quality When Measured Using Inertial Profiling Systems
  • PP 44-01 - Quantifying Cracks in Asphalt Pavement Surface
  • PP 49-08 - Certification of Inertial Profiling Systems
  • PP 50-07 - Operating Inertial Profilers and Evaluating Pavement Profiles
  • TP 76-09 - Measurement of Tire/Pavement Noise Using the On-Board Sound Intensity (OBSI) Method
  • Quality Assurance PP 56-06 - Evaluating the Engineering and Environmental Suitability of Recycled Materials
  • PP 57-06 - Establishing Requirements for and Performing Equipment Calibrations, Standardizations, and Checks
  • Soils MP 9-06 - Compost for Erosion/Sediment Control (Filter Berms and Filter Socks)
  • MP 10-03 - Compost for Erosion/Sediment Control (Compost Blankets)
  • PP 59-09 - Coal Combustion Fly Ash for Embankments
  • cace-01, babakfeyzi, Dell_Brett, kowheng, oanm2000
