Civil Engineering Association eBooks Codes, Manual & Handbook CSC Orion Standard Training Course Manual
 abdulazizk
Ethiopia
User ID: 26237
Threads: 20
Likes: 371 in 30 posts
Given Likes: 178
09-22-2016, 06:33 AM
CSC Orion Standard Training Manual
Size: 9.17 MB | Format: PDF | Quality: Unspecified | Publisher: CSC Orion | Year: 2011 | pages: 245
[Image: 57142291601169247175_thumb.jpg]
1 Introduction
1.1 Background
1.2 Important Notes Regarding This Documentation
1.3 Training Overview
1.4 Overview of the User Interface (for information)
1.5 Orion Modelling, Analysis & Design Flowchart
1.6 Graphic Editor - General Principles
2 Building the Model
2.1 Getting Started – Project Parameters & Settings
2.2 Creating Axes
2.3 Creating Columns
2.4 Creating Shear Walls
2.5 Creating Beams
2.6 Creating Slabs
2.7 Member Re-Labelling (for information)
2.8 Using Tables to Edit Multiple Members
2.9 Wall Loads and Additional Beam Loads
2.10 Generating a 3D View of the Model and Creating Additional Storeys
3 Building Analysis
3.1 Pre-Analysis
3.2 Model Options
3.3 Performing the Analysis
3.4 Post-Analysis
4 Beam Reinforcement Design
4.1 Exercise Aims
4.2 Beam Design Settings and Parameters
4.3 Designing all Beams using Batch Mode
4.4 Graphical Review of Passing / Failing Members
4.5 Interactive Beam Design
4.6 Creating the Beam Elevation Drawings
5 Column & Wall Reinforcement Design
5.1 Exercise Aims
5.2 Column Design Settings and Parameters
5.3 Designing all Columns using Batch Mode
5.4 Creating a Column Schedule
5.5 Creating a Column Output Report
5.6 Creating a Foundation Loads Report
5.7 Interactive Column Design
5.8 Creating the Column Reinforcement Plan
6 Slab Design and Detailing
6.1 Introduction
6.2 Create Slab Reinforcement Strips
6.3 Editing the Bar Layout
6.4 Creating Slab Output
7 Creating a Flat Slab Model
7.1 Introduction
7.2 Creating the Flat Slabs in the Model
7.3 Creating Slab Loads and Openings
7.4 Creating Additional Storeys
8 Building Analysis for Flat Slab
8.1 Pre-Analysis
8.2 Performing the Analysis
8.3 Post-Analysis
9 Gravity Load Chase Down using Finite Element Analysis
9.1 Exercise Aims
9.2 Finite Element Model Generation Options
9.3 Generating/Performing the FE Analysis Model
9.4 Cross checking the Finite Element Results
10 Designing the Flat Slab
10.1 Introduction
10.2 Finite Element – Post Processing Settings
10.3 Floor Analysis Post Processing
10.4 Exporting and Displaying Contours
10.5 Exporting to DXF (for information)
10.6 Designing the Columns/Walls
Appendix A : Wind Load
Specifying Wind Combinations
Applying a Single Wind Load to Each Floor
Applying Wind Loads directly to Columns & Walls
Appendix B: Beam Design Settings and Detailing
Appendix C: Column Design Settings and Detailing
Creating the Column Detail Drawings
Appendix D : Foundation Design
Introduction
Pad Footing Design
Strip Footing Design
Raft Foundation Design
Appendix E : Load Combinations and the Loading Generator
The Loading Generator
Appendix F : Report Manager
Concrete and Form Estimation Reports
Report Manager
Appendix G : Polyline Column Editor
Creating an L-shaped column.
Appendix H : Slab Design using FE Analysis
Introduction
Creating FE Slab Strips
Updating the FE Strips with Reinforcement
Appendix I: Enhancing the General Arrangement Drawings
Creating Dimensions
Shrinking Axes and Setting Unused Axes to Ghost
Creating Slab Section Views
Appendix J : Orion Data File Structure and Project Settings
Project Settings
[-] The following 18 users Like abdulazizk's post:18 users Like abdulazizk's post
  • camto2, blaze, Dell_Brett, slowet, abualamal, Andrew seah, cace-01, oanm2000, malc, Hengki, PinkPant, agelos100, BLESSED DOVE, bridgeengineer, Mannish, rezart, sodapas, jcbv
  Structural steel detailing - Training Manual By Quest dinu69in 2 4,950 10-23-2017, 08:54 AM
Last Post: monter
  FDOT: Grouting of Bridge Post-Tensioning Tendons Training Manual RedHorse 0 1,785 09-27-2010, 08:34 AM
Last Post: RedHorse
