Civil Engineering Association eBooks Structural Books Other Materials (Wood, Brick, etc.) Aluminum Design Manual 2010
 RyanRS
Indonesia
User ID: 32427
Threads: 188
Likes: 4,684 in 228 posts
Given Likes: 765
05-17-2016, 10:24 AM
Size: 10 MB | Format: PDF | Quality: Original preprint | Publisher: Aluminum Association | Year: 2010 | pages: 440 | ISBN: 0982630808
[Image: 66866463437831969420.jpg]
Specification for Aluminum Structures: The 2010 Specification for Aluminum Structures is the first unified allowable strength design and load and resistance factor design aluminum Specification. It provides rules for determining the strength of aluminum structural components and minimum strengths for wrought, cast, and welded aluminum alloys and aluminum fasteners. Commentary: discusses the provisions in the Specification for Aluminum Structures and provides references. Material Properties: includes alloy and temper designation systems for wrought and cast aluminum alloys; comparative characteristics of wrought alloys; foreign alloy designations correlated with US alloy designations; and typical mechanical and physical properties, including thermal expansion, electrical conductivity, and density (all in US and SI units) Design Guide: addresses structural design issues not included in the Specification for Aluminum Structures, including diaphragms, adhesive bonded joints, aluminum composite material, extrusion design, corrosion prevention, fire protection, sustainability, and design references for aluminum structural components in automobiles, bridges, rail cars, ships, pressure vessels, pipe, and storage tanks. Section Properties: lists dimensions and section properties for aluminum channels, I-beams, angles, tees, zees, square and rectangular tube, round tube, pipe, and roofing and siding, as well as sheet metal and wire gauges Design Aids: provides buckling constants, allowable stress tables for various alloys, allowable load tables for channels and I-beams in bending, tread plate, roofing and siding; fastener strengths, minimum bend radii for aluminum sheet and plate, wire, and rod, design stresses for groove and fillet welds, and beam formulas Illustrative Design Examples: includes structural design calculation examples based on the Specification for Aluminum Structures.
[-] The following 38 users Like RyanRS's post:38 users Like RyanRS's post
  • rezart, f_slikken, titko, cace-01, shaker, PinkPant, sabooryan, blaze, oanm2000, malc, Jackass, uncblue, mgdario, Dell_Brett, rendel_©, knrsa, ykhackhack, bridgeengineer, Tarik, Hengki, er.shyams, milova, monter, slowet, araza023, gulilero, draluka, Trishu999, harsono, xdesi, jayborre, hodzicemir, mkat2003, pousin, bigone, zrilek, mohamz, Wijono
 bigone
User ID: 4505
Threads: 92
Likes: 5,722 in 517 posts
Given Likes: 7145
02-09-2020, 07:51 AM
Mirror link
2010 Aluminum Design Manual
[-] The following 13 users Like bigone's post:13 users Like bigone's post
  • zrilek, Andrew seah, PinkPant, Dell_Brett, mohamz, jcbv, pedzaquino, subin91, avge, haze, oanm2000, Aviator, cace-01
  Aluminum structures: a guide to their specifications and design abudabeeja 9 6,311 06-22-2017, 04:58 AM
Last Post: concreteok
  Basic structural design considerations and properties of glass and aluminum structure TAFATNEB 0 1,853 10-25-2012, 09:36 PM
  Aluminum Design and Construction rendel_© 5 4,008 08-06-2012, 08:56 AM
Last Post: shadabg
  Basic structural design considerations and properties of glass and aluminum structure tunaungkyaw 1 2,779 07-27-2012, 01:23 AM
Last Post: tunaungkyaw
