04-16-2016, 06:15 PM
Detail Practice: Dry Construction
Author(s)/Editor(s): Karsten Tichelmann | Size: 52 MB | Format: PDF | Quality: Original preprint | Publisher: De Gruyter | Year: 2008 | pages: 112 | ISBN: 3764388080
Detail-Practice: Dry Construction provides an overview of the most widely used dry construction systems, organized according to the building components wall, ceiling, and floor and their applications. The volume is conceived as a practical manual for design and planning. Dry construction in interior design employs dry construction systems in place of moisture-retaining materials such as concrete and plaster. Not only is this construction method cost-effective, since the full range of physical requirements, including thermal, cold, and sound insulation, fire safety, etc., can be satisfied. Thanks to the use of new material technologies, it also affords the designer nearly unlimited freedom, since the surfaces involved are almost infinitely malleable as well as multifunctional, capable of assuming the tasks of lighting, heating, and cooling. The general section is supplemented by examples from existing projects with clearly visible reference details as well as from special constructions, for example, in damp locations. The book shows the potential this construction method obtains from the use of new materials and construction systems. As in the preceding volumes of the series, standard drawings are used to illustrate common construction details.
